Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
  • 489 Answers
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
Posted on May 28, 2009
  • 975 Answers
This is what it means:
go to this link , theres about 2 versions of this code , hope this helps , AJ
click here:
http://www.copytechnet.com/forums/canon/16164-canon-ir-3530-a.html
How do reset my canon mx370 printer error code 5b02
Have you tried disconnecting it from the mains supply for about 15 minuets ..? some times this clears the problem by wiping the memory,
but before you reconnect make sure you have ink and paper in the
machine.Otherwise contact Canon customer helpline they have someone there who can tell you what error 5B02 actually means ,T.C.
Mar 31, 2013 | Office Equipment & Supplies
My lbp5000 prints the colour image seperate from the black image, although it's supposed to be one image
The printer is need to Calibrate. Calibrate the printer from the menu in the taskbar down/right to the clock. Calibrate several times until printing is good.
Jan 08, 2011 | Canon LBP5000
Canon LBP5000. The printer has stated to print a shadow image of the darker parts of the print. Not always from the start but after some prints. The shasow image can also be from the previous print. It is...
Had the same problem with LBP5000. Used the Cleaning Utility(Options/Cleaning) in the printer software, had to run it several times, the shadow did not go away the first time. Looks all right now.
Hope this helps.
Thor.
Nov 08, 2010 | Office Equipment & Supplies
Lbp5000 two sides print
LBP5000 doesn't have a duplexer for automatic double sided printing, so it's maual duplex.
You have to print on one side, then put the paper in the paper tray again. Take note of the pictogram that shows a printed page with the corner turned over, this indicates wich way you put the paper in (for the print you are about to make, not what is already on the paper)
Dec 09, 2009 | Canon LASER SHOT LBP-5000 Printer
My new computer can't talk to my Canon LBP5000
Your unit will work only on vista 32 bit system check canon for more details
Sep 11, 2009 | Canon LASER SHOT LBP-5000 Printer
E16 error
Hi there.
E16 Error code means (on all canon compacts) that there is something wrong with the lens mechanism and it cannot contract/extract/focus etc. Basically, if the problem is not fixed by removing the batteries for 20 minutes and reinstalling them (make sure they are fully charged) then you'll have to take it into a shop or get a friend who knows a lot about this stuff to take it apart.
Good luck and thanks for using FixYa!!
May 07, 2009 | Canon PowerShot A85 Digital Camera
I have an error code on my printer Error Code: E100 0000 E100 0001 it is a canon LBP5000
Well im having the same issue E100 error on my xbox one as it was never update till the other day i was thinking is it possible if the nand dumpable and get the keys or signature from it and replace it with a working nand i know it still works cos i able to do the recovery mode with the offline update dianogtic from microsoft but still error E100 after reset
For more help visit cbr tech solutions
Sep 04, 2008 | Canon Office Equipment & Supplies
Error Code
The error code is saying you have a fuser fault
Try resetting the machine
get into service mode
then COPIER
then FUNCTION
then CLEAR
then ERROR
then OK at the bottom right hand corner
if you dont know how to get into service mode
call me 00447764303923.
Feb 15, 2008 | Canon imageRUNNER C3200 Copier
3,495 people viewed this question
jasbo
jasbo
