Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Hi I am facing a problem Seagate SATA HDD, like when i am going to install the OS it will no install its showing a blank screen, HDD was detecting BISO & also when i connected to secondary devic
Hi I am facing a problem Seagate SATA HDD, like when i am going to install the OS it will no install its showing a blank screen, HDD was detecting BISO & also when i connected to secondary device also its not showing the drives but it show in Device Manager. In that HDD I have most important data , I want to take back up..... What should I do .. Please help me about this Sir Its very very urgent to me Thanks & Regards Prashanth
    Scholar:
  • 120 Answers
You're probably going to have to go back to the machine that it came out of to boot it. Unless you can boot as a primary (it was the boot drive?) in safe mode.
Posted on Jul 08, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 27 Answers
Memory stick?
Posted on May 28, 2009
Why does Windows not automatically detect Seagate 1F2168-300
1. You need Windows 7 or 8
Earlier OS can support up to 2TB max.
2. Even with Windows 7 or 8, 4TB HDD cannot be used as System
unless you have UEFI bios.
Apr 16, 2014 | Seagate 1F2168-300 4tb 5900rpm 64mb buffer...
My Dell Inspiron 1545 laptop is not recognizing seagate free agent go 500 gb external disk. It used to work fine all the while until I used it on another system. I have tried changed the usb cable but...
check in the bios if it is showing HDD detected
.if there in bios HDD not detected then there is problem with HDD (change the HDD ) or
go in bios and ...check sata settings
.change the sata settings n then ...install again
Jun 28, 2011 | Computers & Internet
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Brand new Seagate barracuda 500GB SATA hdd not detected
http://www.seagate.com/staticfiles/support/downloads/firmware/ http://atulchitnis.net/files/seagate.pdf
Jun 20, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
then
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Sata hdd detected but problem with booting&installation
i have sata hdd 160 gb of seagate and hdd detected in raid channelbut when start installing window it shows message press enter for fresh installation "no hdd found please check power card,bios configuration
Jun 30, 2008 | ASUS P5RD1-VM Motherboard
Sata driver
check for the website of your HDD vendor.eg-www.seagate.com for seagate hdd.
make sure you format using fat32 file system.
Jan 28, 2008 | ASUS K8V-MX Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
256 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
