Question about Microsoft Windows XP Professional for PC
I need the windows genuine advantage cracked or legitcheck.dll
I need the windows genuine advantage removal or cracked or legitcheck.dll
  • 489 Answers
My screen appear you are a victim of software counterfeiting how to erase this or resolve it thank u
Start Windows Registry editor and delete the folder "WGALOGON" located in the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ Windows NT\CurrentVersion\WinlogonNotify. Delete all references in your registry to WgaTray.exe
Another alternative suggest that three files are installed Windows XP System Folder:
\WINDOWS\system32\WgaLogon.dll
\WINDOWS\system32\WgaTray.exe
\WINDOWS\system32\LegitCheckControl.dl...
The wgatray.exe process makes the check for genuine windows software. You can disable WGA by removing the execute bit on WgaLogon.dll. That way, winlogon can't call it as a notification package at boot, and since WgaLogon is responsible for running and maintaining WgaTray.exe, no more tray popups either.
To change the execute bit of WgaLogon.dll, first turn off Simple File Sharing. Now right click the file in Windows Explorer and open the Security Tab. Hit the Advanced button, uncheck the Inherit box at the bottom, hit the Copy button, then hit OK. Go through each listed user/group and remove the "Read & Execute" permission for that file, leaving the "Read" permission as-is.
Hit OK to apply the permission changes and close the file properties dialog. Restart the machine. You can now turn "Use simple file sharing" back on, if you want.
A third alternative posted on the internet suggest that users clear the content of file data.dat located in the following directory:
C:\Documents and Settings\All Users\Application Data\Windows Genuine Advantage\data
Save the data.dat empty file and change the attributes to "Read Only" - Restart you computer. Or start your PC in Safe Mode and delete the following files from Windows system32 folder - wgalogon.dll spmgs.dll wgatray.exe The WGA setup file is in C:\WINDOWS\SoftwareDistribution\ Download\6c4788c9549d437e76e1773a7639582...
If you don't use "Fast User Switching", you can disable the Windows XP Welcome Screen if you are logged in as an Administrator. This will remove the initial WGA Warning Screen:
1. Click on Start -> Control Panel ->User Accounts
2. Click on "Change the way users log on or off"
3. Uncheck "Use the Welcome Screen" - Choose Apply
4. Close the User Accounts window and the Control Panel
5. The next time you reboot your computer, the classic login prompt will be used
To enable Fast User Switching, you must also enable the Use the Welcome screen option. Also, Fast User Switching cannot be used when Offline Files are enabled.
Disable wgatray.exe - Some users are claiming that removing the WGATray.exe (or killing the WGATray.exe process) are working for them. Here's how to search for WGATray.exe file - Screenshot
None of these methods are guaranteed to work and people are just experimenting. Meanwhile Microsoft is not willing to relent to crackers this time and are planning to release an update of WGADiag2.exe utility in the next few days.
WGADiag2 will also fix the problem with registry key permissions may cause the installation of Windows Genuine Advantage Notifications KB905474 to fail from Windows Update:
Here's a manual fix provided by Microsoft. These permissions can be repaired using Registry Editor as follows:
1. Click Start, and then click Run
2. In the Open box, type regedit, and then click OK
3. Expand HKEY_CLASSES_ROOT
4. Locate the subkey HKEY_CLASSES_ROOT\LegitCheckControl.Legi...
5. Right-click the subkey and select Permissions....
6. Ensure that Administrators allowed Full Control permission
7. Repeat steps 3-6 for the subkey
HKEY_CLASSES_ROOT\LegitCheckControl.Le...
Microsoft has also published a kB article if the Windows Genuine Advantage (WGA) validation check process does not validate successfully on a Microsoft Windows XP-based computer, and you receive one or both of the following error messages:
Product Key Inaccessible 0x80080212
This problem occurs when you do not have the appropriate permissions for the Windows Genuine Advantage\Data folder. In the Permissions for Users section, make sure that Read & Execute, List Folder Contents and Read permissions are given. If the previous steps fail, start the computer in Safe Mode and rename the %allusersprofile%\Application Data\Windows Genuine Advantage directory.
May 20, 2011 | Computers & Internet
Tip
How to Remove Windows Genuine Advantage Notifications
Different Ways to remove windows genuine notification error
You might be annoyed by the above notification if you are not using a genuine widnows Operating system. There are many ways to remove this WGA notifications .. Here we are giving some simple step by step instructions to remove this notification. Step 1: System Restore
If you have done Windows update and got windows genuine notification error, you can do a system restore. Restore to a point where Windows update is not done.
Step 2: By Deleting files manually
To remove WGA manually Navigate to the below location and delete wgatray.exe and wgalogon.dll C:Windows\System32\wgatray.exe C:Windows\System32\wgalogon.dll
Step 3: Delete WGA entry from registry
Access Registry by typing regedit in RUN and Navigate to
HKEY_LOCAL MACHINE \Software \Microsoft \Windows NT\ Current Version\Winlogon \Notify Wgalogon
You need to right Click on Wgalgon and delete it and restart your PC
on Jan 20, 2010 | Microsoft Windows XP Professional With...
Tip
Different ways to remove windows genuine advantage notifications
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step 1: System Restore
C:\\Windows\System32\wgatray.exe
C:\\Windows\System32\wgalogon.dll
HKEY_LOCAL MACHINE\ Software\ Microsoft\ Windows NT\ Current Version\Winlogon\ Notify\ Wgalogon
on Jan 15, 2010 | Microsoft Windows XP Professional
Hi sir i hope you weill be fine dear sir i want to remove victum of software counterfeiting which is ceart problems of my system please solve this problems
You want to remove Windows Genuine Advantage.
In doing so it will strip all the security features Mirosoft uses to check if you copy of windows is owned.
http://www.mydigitallife.info/2010/06/13/download-windows-genuine-advantage-wga-validation-crack-1-9-42-0/
Nov 30, 2010 | Microsoft Windows XP Professional
Acivar mi office 2007
click start...computer...double click local disk
C: (hard drive)...then Windows...then system 32.
then look for these files:
OGAAddin.dll
OGACheckControl.dll
OGAEXEC
Then move those files to a different location
(e.g. my doc's),don't just copy them, move them
(drag and drop), or rename them, or delete them,
you should then have no more problems with genuine
advantage. Just be sure not to accept updates
automatically and don't update MSOffice 2007 or
accept any Genuine Advantage Update
never worry again
Oct 22, 2010 | Microsoft Office Professional 2007 Full...
Windows genuine advantage
I am afraid not.
If it a geuine copy Microsoft can help with any issues regarding activation.
They are not awful people to deal with and I have transfered my copy of windows to many computers without issue.
Sep 10, 2009 | Microsoft Windows XP Home Edition
When I try to validate my Windows version I get an ActiveX error
turn pop up for cookies on, certain activex controls would popup in the seperate windows for that popup should turn on...
Mar 23, 2009 | Microsoft Windows XP Home Edition
I have problem with my desktop.
Try to follow some of these methods:
First Method
  1. Lauch Windows Task Manager.
  2. End wgatray.exe process in Task Manager.
  3. Restart Windows XP in Safe Mode.
  4. Delete WgaTray.exe from c:\Windows\System32.
  5. Delete WgaTray.exe from c:\Windows\System32\dllcache.
  6. Lauch RegEdit.
  7. Browse to the following location:
    Windows NT\CurrentVersion\Winlogon\Notify
  8. Delete the folder ‘WgaLogon’ and all its contents
  9. Reboot Windows XP.
Note: With this method, you may be prompted to install WGA Notifications again which can still be unselected.
Second Method
Another alternative suggested by dman is by using System Restore to restore the PC to a previous restore point that WGA Notifications hasn’t kicked in, and then carefully stop KB905474 from been applied to the system. To use System Restore, go to Start -> All Programs -> Accessories -> System Tools -> System Restore.
Note: Again, you may be prompted again to install WGA Notification, so it must be bypassed.
Third Method updated
This method involves using a cracked version of LegitCheckControl.dll to replace the original copy of LegitCheckControl.dll, and thus bypass the WGA validation and make Microsoft believes that your copy of Windows is genuine. To get rid of WGA Notifications warning messages, the patched version of WgaLogon.dll and WgaTray.exe to replace the existing files.
To apply the patch by replacing the files manually, try to end the respective processes in the Task Manager before deleting the existing files. Most likely is you will have to restart your PC in Safe Mode in order to replacing the original copy of LegitCheckControl.dll and related files. However, there has been automatic updater and even cracked WGA installer that automatically apply the patched version of WGA files.
Latest Update for WGA version 1.5.708.0 latest
Download cracked and patched version of LegitCheckControl.dll with thanks to Danny.
Latest Update for WGA version 1.5.554.0 latest
Download cracked and patched version of LegitCheckControl.dll, WgaLogon.dll and WgaTray.exe for v1.5.554.0 of Windows Genuine Advantage Validation Tool and WGA Notifications.
rate me if this works.
Mar 22, 2009 | Microsoft Windows XP Professional With...
Remove ask for genuine microsoft software? by windows xp professional pc
it\'s so easssssssssy
Just download this tool from Softpedia
http://download.softpedia.com/dl/ea657e5450a2e6ff97a5eb30d6bb847a/4a3d05f5/100042782/software/tweak/RemoveWGA.exe
Moktar
Feb 19, 2009 | Microsoft Windows XP Professional for PC
Getting nonerasable warning from Microsoft!!!!!!!
You seem to be a victim to piracy from your local vendor. You can report him to Microsoft and receive a finder’s fee, which isn’t going to cover the cost of new Windows XP. So here are some alternatives.
With new release of WGA, some methods no longer works, and some has been updated. Several methods that has certain success on certain people, you may try until you success.
Official Method by Microsoft - more information here. http://www.mydigitallife.info/2006/06/28/official-ways-to-disable-or-manually-uninstall-the-microsoft-windows-genuine-advantage-notifications-from-microsoft/
or:
First Method
  6. Lauch RegEdit.
Second Method
Another alternative is by using System Restore to restore the PC to a previous restore point that WGA Notifications hasn’t kicked in, and then carefully stop KB905474 from been applied to the system. To use System Restore, go to Start -> All Programs -> Accessories -> System Tools -> System Restore.
Download http://www.mydigitallife.info/2006/09/27/remove-bypass-patch-and-disable-microsoft-windows-genuine-advantage-wga-validation-version-157080-with-legitcheckcontroldll-crack/
Download http://www.mydigitallife.info/2006/10/08/crack-and-patch-to-bypass-and-disable-wga-genuine-windows-validation-and-notifications-version-155540/ of Windows Genuine Advantage Validation Tool and WGA Notifications.
In the short of it, sometimes it worth to just get a legitimate copy so your problem will go away. Unfortunetely being the victim really sucks, because this will for every be a problem if you do any updating of MS software. If you look around (eBay etc) you may find some pretty good deals on Windows XP.
My best of luck to you.
Mark
Dec 31, 2008 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional for PC Logo
261 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
