Question about Kenwood KDC-MP919 CD Player
KDC-MP919 No display
My kenwood deck isn't working. Well everything else works, except for the display on its regular position. When I press the eject button so that the motorized faceplate is horizontal, the display seems to work. When its back in its regular vertical position, theres nothing on the screen. Everything else works okay, its just the display. Anyone have any answers for this? I had this same problem about 4 years ago and it cost me $140.00... Now my display light for the buttons don't work, so at night I can't see anything... I refuse to more money into this radio. For what it would cost to repair, I can buy a new one with better options...
    Novelist:
  • 149 Answers
With the amount of use in four years I will say you definatly got your moneies worth from it.  From the way it sounds, there is a small paper thin ribbon cable that connects from the main body of the radio to the head unit itself.  With the amount of times this thing has been used the ribbon cable sounds like it has finally gone bad.  The best way for me to have you demonstrate this is to take a piece of paper and with a razor cut a **** in the middle of it and then folt the paper in the same direction as the ****.  When the cable is flat the wires in the cable make connection and when the cable is bent there is no connection to certain areas of the cable.
Posted on May 28, 2009
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
Display screen not working
Sounds like you might have a bad connection where the faceplate connects to the unit, or the faceplate is bad.
May 21, 2010 | Kenwood KDC-X590 CD Player
NEED INPUT
http://inform3.kenwoodusa.com/manuals/kdcx859.pdf this is the website to look at the manual for this deck
May 08, 2010 | Kenwood KDC-MP919 CD Player
The deck gets power but wont function.When its on, the faceplate rolls over & then it freezes.
there is a flexible cable that goes from the face to the main motherboard. the cable is most likely bad and needs to be replaced.
Apr 06, 2010 | Kenwood KDC-MP919 CD Player
Kenwood KDC-MP428 - the display is out but works otherwise
there are several surface mount resistors on the right side inside of the deck that need to be resoldered.
Jan 07, 2010 | Kenwood KDC-X590 CD Player
Kenwood KDC-MPV619. No remote. Need unlock code for deck.
I had the same problem with my kdc-mpv619. I had bought a new truck that didn't have a remote and the screen says enter code. You do need a remote to fix it, but what they don't tell you is a universal remote will work. I used my direct tv remote and looked up all the codes for kenwood.
The one that worked for me was 30337 (not sure if that would work for you).
1) The way I tested it was go to my stereo and I held down the display button + volume up button. (This should remove the - - - - sign but it will still say CODE).
2) Then you press the 5 button on the remote and if the screen says CODEK then you know the remote works.
(to switch from K to C to A to R press the (>>) button on the screen.
3) Enter the code KCAR (the display will say CODEKCAR)
4) Final Step is hold do the fast forward button (>>) on the screen.
It should work for you after that ;-)
Apr 30, 2009 | Kenwood KDC-MPV619 CD Player
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
You probably have a break in the flexible ribbon cable that goes between the flip face and the mother board. Try partstore.com for a replacement cable.
May 24, 2007 | Kenwood KDC-MP919 CD Player
Kenwood KDC-MP919 CD Player Logo
204 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
