Question about LG WM1814CW Front Load Washer
Cold water will not shut off even when washer is off.We left unit unpluged over nite and still have same problem
  • toxalot Jan 02, 2008
    water will not shut off even when machine is finished. No codes alerted me to any problem. I have to turn off the water to keep the machine from filling up by itself.
  • crank383 Jan 30, 2009
    I have a frigidaire washer dryer combo that does the same exact thing! Been doing it since it was 3 months old, Did not buy warranty. Have to shut water off during every cycle while washing and rinsing. THANKS, Tom
  • LG Master
  • 4,655 Answers
It is possible that the water solenoid is stuck open, sometimes they can be cleaned and yet sometimes they will need to be replaced
Posted on Oct 22, 2007
Odds on is the pipe from the drum to the pressure solenoid switch is punctured. This switch turns off the inlet valve when the drum is filled sufficiently. If it has a hole in it, the machine will just keep filling up. Switch is usually at the top of the machine. - Rick
Posted on Jan 14, 2008
2 Suggested Answers
yalmer
  • 552 Answers
SOURCE: Cold water will not shut off
You have a stuck cold water solenoid valve.
Try openning the machine and tap on the cold solenoid valve.
If this dowes not work, you may have to replace the valve.
Posted on Mar 25, 2008
Whirlpool front loader -new washer - put in gentle load and keeps shutting off part way with LF -kept trying to start over, even unplug but keeps doing it -have about 5 small items - cold water only -have...
As it's new it will still be under guarantee/warantee? I strongly advise you contact their service desk as you could invalidate the guarantee by following other's guidance. I'm interested in why you have shut off the hot water? Once the temperature is selected by the user, the washer automatically uses a mix of hot and cold water, or just selects cold for rinses etc..
Has the 'LF' been coming on BEFORE or after you shut off the hot water?
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 16, 2011 | Whirlpool Washing Machines
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Cold water valve does not shut off
The valve has trash in it. Take it apart and clean it real good with soap and water and brush.
May 31, 2010 | LG WM-1832C Front Load Washer
My Washer is flashing an error message. F27
Error code f27
OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.
Check
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Good luck
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite quietpak9 HE4T washer FH error code
take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem.
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
Nov 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Cold water will not shut off even when washer is off.We left unit unpluged over nite and still have same problem LG washer # wm1814cw overfills
Mar 25, 2008 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
280 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
