Question about Hotpoint Ultima WF860 Front Load Washer
Error Code "TEST"
My Ultima Super Silent keep flashing up with "test" and now its not letting me run any washes, please help?
Just had the same problem & found the following solution via the web :-
1. When tESt shows hold down both the ON/OFF Button & the START Button together & let the Test proceed holding the two buttons down for the entire test (Approx 3 Minutes ) .
Continue to hold the " buttons down until the word Done appears.
After which you should be able to proceed with the normal wash cycle
Posted on Jun 01, 2009
Peterjeav,s solution works fine many thanks
Posted on Jun 08, 2009
Thanks to peterjeav was so helpfull cant live without a wahing machine ha
Posted on Jun 03, 2009
Hi, i have washer / dryer "Hotpoint Ultima Super silent WD860" with an error code F13 when trying to use the dryer Please advice Thanks
Check the water supply, inlet valve, and hot & cold hose connections.
Got this piece of advice from their site..
Hope this helps.. :)
Jun 10, 2011 | Hotpoint Washing Machines
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Dec 14, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
My hotpoint ultima super silent displays 'test' but dnt run cycle
its in factory test mode, this can be set by pressing the on and start buttons together. to reset, turn on while pressing the on and start together until dOFF appears
Jan 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent wash wt 960
i rang the service engineer and they looked up the code, it was something to do with overheating, they are sending someone to fix it soon!
Dec 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Aug 27, 2008 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
269 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
