Question about Dell 810 All-In-One InkJet Printer
Help every time i try to install my dell 810 it says it only works with a usb cable but for soe reason its set to a port.
  • 489 Answers
There is a convertor from Com to Usb that you cant see. it say  set a port for com.
Posted on May 28, 2009
Dell Precision T1500 beeping 6 times and will not boot up.
Remove whatever USB cables in the front USB ports below the DVD. Then try starting it should work. If not remove USB from the rear one at a time. Once it restarts replace USB cables into ports.
Mar 11, 2013 | Dell Dimension 3100 PC Desktop
My computer does not recognize my printer
Ensure you use the right driver to install your printer. Browse www.support.dell.com to get your printer model driver. And you will find it work.
Jun 10, 2011 | Dell 946 All-In-One InkJet Printer
After I reinstalled my dell all-in one 810 printer it not scan anymore it works only if I run scan wizard from accesories but not from all in one center or by pressing key on printer
Try to update the driver on the devicemanager
go to start > right click computer > properties > device manager > go to imaging device > right click the tab that appears usually its thedell click update the driver
incase nothing happens
- try to unplugged the USB restart the computer once your computer completely restarts plugged in again the USB
- or you may try to unplugged the USB first , right click dell tab > uninstall
restart your computer once it completely on plug in the USB ..
hope it help you may also try paint for scanning cLICK filE > from scanner or camera ..
Usually all printer has an appliaction for scanning
your last resort forthis one is uninstall the driver and install the driver from dell.com
click the link below hope it help
http://search.dell.com/results.aspx?spf=Printer&ssysid=PRN_ALL_A810&ssysn=810+%28Photo+All-in-One%29&s=dhs&c=us&l=en&cs=19&ec=&ira=False&cat=sup&subcat=dyd&rf=all&evl=&nk=f&k=dell+810+printer&p=1&nf=&rpp=12&sort=K&~srd=False&ipsys=False&advsrch=False&p=1
May 28, 2011 | Dell 810 All-In-One InkJet Printer
My dell 924 printer has stopped working. I get an error message that there is no USB connection. All connections & USB cable are fine. For some reason this printer is no longer on a USB port - have...
Hello.
It sounds like a issue with the hardware inside the printer. if possible try the printer on another PC, or try another USB Cable. Sometimes the cable can appear fine but can have small breaks inside it. You can also try your current cable on another persons printer to rule out the cable.
If you can not get the printer working on another persons computer I would suggest replacing it. it is cheaper than getting a tech to fix it.
Regards GM
May 27, 2011 | Dell 924 All-in-One InkJet Printer
Printer offline
One possible reason could be that manually printer had gone offline.
You can go to Control panel - > printer & Faxes settings and right click your printer and click on user printer online. If you doen'nt find this option on right click means it is already in online mode, but somehow not able to communicate to the printer. Right click the printer and go to properties, click on port tab search for USB port and select USB.
Refer to the operating manual for printing test pages from printer.
http://support.dell.com/support/edocs/systems/1710n/en/om/1710_en.pdf
Also refer to Dell forums on how to reset photo conductor
http://en.community.dell.com/support-forums/peripherals/f/3528/t/18405962.aspx
Hope this helps
Jun 01, 2010 | Dell 1710 Laser Printer
No high speed usb port
Hi Delvin!
The 2 usb-ports on the front and the 3 back of your Dell is high speed ones, at least the manual says so, they are all USB 2.0.
If you cant get them work properly with the 2.0 usb speed, you can buy an high speed pci add-in- card and install it on your pc.
Here you can read about the "high speed usb" :
http://www.usb.org/developers/usb20/
And here is the manual and avalible drivers for your Dell:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
Good luck to you M8!
Please take a moment and rate my help for you
Nic
Feb 23, 2009 | Dell Dimension 1100 PC Desktop
How Can I Fix Problem
Open your printers folder and make sure you do NOT have a bunch of duplicate installs. If you do, delete them all and then install just one. Be sure you have a good USB cable. Try using the same cable on some other USB device that usually works. If that device wont work with the printers USB cable, its most likely a bad cable. also try using a different USB port. I have seen a lot of computers that have a problem with USB ports suddenly dieing for no apparent reason.
Feb 11, 2008 | Lexmark X1270 All-In-One InkJet Printer
New installation 810, printer works A1, scanner won't work
Uninstall and reinstall the software. Normally the software installed on the computer controls the scanner functions for the all in one dell stuff. Check dells site also for any updates that might correct this issue.
Jul 08, 2007 | Dell 810 All-In-One InkJet Printer
Dell All-In-One 810 Printer installation problems
From what you describe the printer is not installed correctly. I would try uninstalling everything associated with this device, unplugging it and then retry the installation process again. I don't know if the instructions are clear but you should not connect the USB cable to the printer until after the software is installed or when prompted by the software wizard.
Jan 01, 2007 | Dell 810 All-In-One InkJet Printer
HotSync fails using PalmConnect/Palm V on XP-Pro Tablet PC
This one is simple - Tablet edition is not supported. Sorry to break the news to you but palmOne soes not support synchronization with Tablet editions of Windows. If you can get it to work, great but you cannot get direct support for it.
Sep 11, 2005 | Palm V
Dell 810 All-In-One InkJet Printer Logo
51 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
