Question about Maytag Washing Machines
No warm or hot water entering washer
No hot or warm water entering washer
  • joemc542 May 28, 2009
    already cleaned them and still have cold and no hot
Clean inlet filters for water supply hoses coming into back of washer. There two small screens on the inlet fittings, "back of washer" that must be removed and cleaned once yearly.
Posted on May 28, 2009
  • 1073 Answers
SOURCE: New WTW5700SW clothes washer.
the temp thermister in the control panel is bad, lowes has a 30 day return policy if they delivered it have them bring you a new one, if you picked it up take it back, get a new one no need in starting out with an new almost out of the box washe with problems
Posted on Apr 13, 2008
gdmisp
  • 66 Answers
SOURCE: hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Posted on Jan 16, 2009
jsrock516
  • 5911 Answers
SOURCE: no hot water from my washer
The problem is your HOT water solenoid on the water inlet valve. On some washers this is also known as the mixing valve. Since the washer uses hot water for both the hot and warm settings, its logical to assume you have a solenoid that isn't operating. The following link gives you the necessary steps to replace the inlet valve (if necessary):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
The first thing you can try is to determine if the valve may be clogged. If you live in an area that has hard water, or if you use well water, sediment can build up in the filter screens of the valve. You can access by turning off the water supply and removing the hose from the back of the washer. The sediment screens are located in the valve fitting. Sometimes the hoses have restrictor screens in the ends that can also clog or obstruct water. Try cleaning with some distilled vinegar and cotton swabs to dissolve any deposits.
Another source of the problem, could be the electrical connection to the solenoid. With the exterior washer case removed, you can access the electrical connections to the valve and remove them. Clean the contacts if corroded.
If all these preliminary steps do not solve your problem, replace the valve. A replacement can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. Just type in your model number for your search criteria. All these sites offer great service with competitive pricing, so shop around for the best price.
If you have questions along the way, let me know. I hope this helps you.
Posted on Jun 12, 2009
garing
  • 998 Answers
SOURCE: I have connected a new washer to a tankless water
change inlet valve(note the way the wires are on it take inlet hoses off remove screws that hold unit in place remove old one and install new one)
Posted on Aug 25, 2009
tbirdfan1
  • 3051 Answers
SOURCE: washer only has cold water.
Hello there
The Water System temperature sensor is normally what is wrong with these units with this condition that you are experiencing
The water system consists of the hot and cold water inlet valves, a water temperature sensor, a water
flowmeter and control and the dispenser distribution system along with a traditional pressure switch.
Water Inlet Valves -
The hot and cold water inlet valves are located at the back of the washer. These valves receive a control
signal from the Central Control Unit to manage the temperature of incoming water. The temperatures
are determined by the specific wash cycle selected and a temperature sensor located in the wash tub.
To improve cleaning of heavily soiled clothing and to provide a sanitizing feature, the water temperature
can be increased through the use of a heating element located in the bottom of the tub
Posted on Dec 25, 2009
My washer will not work. It will not fill unless the washer is on warm warm, hot warm anything but cold. Otherwise I get NO water. It will spin. But I can only get hot water. Not even warm water.
One of two things, easy one first, the cold water inlet screen on the back of the machine is clogged preventing cold water from entering,or more likely the mix valve has gone bad (the cold water solenoid) replacing the mix valve is not hard on these for a doit your selfer and the parts are less than $ 50.00
Sep 18, 2010 | Kenmore 24032\24036 Top Load Washer
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Cold fill washing machines
If your washer is the type that all rinses are in cold water only this would make sense that in the winter months when the water is at it's coldest the clothes will feel cold after the spin cycle.
If your washer has a warm rinse cycle and when you select the warm rinse option the clothes feel cold after the spin, then maybe the hot water supply line is plugged.I recommend disconnecting the hot water hose at the back of the washer and check the screen that is at the fill valve on the washer and make sure it isn't clogged with sediment or calcium build up or any other foreign material that would keep the hot water from entering the washer.If all is well there, suspect either the water temp selector switch or the hot water fill valve. Good luck !
Jan 23, 2010 | Washing Machines
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
Can't get anything but warm of hot water
If you set the washer for cold wash with a cold rinse, no hot or warm should enter the machine. If any hot or warm enters machine on cold / cold, check to see if the hot and cold hoses are hooked up correctly, and not reversed.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
When you start a cycle, a small amount of water will run into the washer and it will sit and do nothing then the pause button flashes. But it will not finish a load even if you continue to hit the pause...
Apr 01, 2009 | GE WBVH6240F Front Load Washer
Water temperature
It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
Aug 26, 2008 | Maytag Washing Machines
Washing Machines Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
