Question about JVC TH-S8 System
JVC TH-S8 DVD SURROUND SOUND - NO SOUND
The sound just stopped working on my JVC dvd player. If I plug in headphones it works. Suspect its the actual sub at fault.
Any ideas or where I can get a replacement sub
  • 29 Answers
SOURCE: NO SOUND From JVC TH-S5 Home cinema system
First, make sure it didn't get muted, or the remote's volume got turned way down. Next, it might be time to involve a technician who can check all the power supply voltages. Many of today's electronics have multiple voltage power supplys, 5 volts for logic, 12 volts for motors, and amplifiers usually have the biggest- maybe plus and minus 30 volts for a total of 60. There are hazardous voltages in there too, a switching power supply starts with over 300 volts. So don't lick it and see if your tongue tingles, that's only for 9 volt batteries.
Posted on Jan 29, 2008
SOURCE: Setting Up Surround Sound with satellite tv digital tuner
What model do you have?
You should be able to plug the audio/video output from the satellite TV system into the audio/video input on the JVC system. Then set the JVC system to the appropriate input.
I need to know the exact model to know how or if this is even possible. Some JVC models don't let you input any additional devices. Others might not have the inputs that are necessary for surround.
Posted on Mar 19, 2008
SOURCE: jvc th-s8 no sound
There is a stock fault on the sub woofer unit.
R2702 fusible resistor is likely to be faulty.
Here is their modification - dodgy english but you get the idea.
Reasons: R2702 (QRZ9005-470X) a 47 Ohm 1/4W resistor is open circuit due to rush current at the time of
power supply ON/OFF.
Cure: 1) R2702 change value : QRZ9005-470X --> QRJ146J-220X
2) C2704 change value QETN1EM-107Z --> QETN1HM-476Z
Posted on Dec 19, 2008
SOURCE: Cannot TV to play throught JVC TH-C50
i have a jvc th-c60 and only recently started using the system for surround on my tv.
in addition to the surround system, i have a conventional vcr/dvd player. i mention this because i have my cable line routed through the vcr/dvd player - all other connections (audio in/out, etc.) are directly from back of tv to surround unit console. assuming all connections are correct, set the jvc unit to show "VCR" on the unit display AND set your surround option to "All surround". The "all surround" may not the exact term, and not sure what your unit has the same notations, but you should be able to cycle through the surround options and determine when you have sound coming from all speakers. also, on my th-c60 unit, the unit display denotes which speakers are producing sound (or should be producing sound).
and, yes, the college football games sound awesome in surround mode.
Posted on Jan 09, 2009
SOURCE: NEED CORD FOR JVC SURROUND SOUND SYSTEM MODEL
Ebay, search for jvc cord 8 pin
Posted on Nov 06, 2010
I have a JVC surround system, I have power to both the DVD player and the Subwoofer but no sound. Wheni plug in earphones to the dvd player there is sound but nothing when unplugged. Could it be the S
You must have an external cable connection from the DVD audio output to the surround DVD input. As well there should be an output from the surround marked subwoofer. Connect them with the proper cable
Apr 04, 2012 | JVC TH-S8 System
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
Oct 19, 2010 | JVC TH-G30 Theater System
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
Surround sound dvd player/tv channels are fuzzy
Hi I have an RCA Truflat TV and a philips Surround sound dvd all in one system and a jvc dish system. I have had my surround working up until my nephews messed with it and hooked up a wii system to it. Now I get no sound on my surround sound and I have tried rearranging the cables but I can not get any sound from the surround sound and for the life of me I can not rember how I originaly had it set up. can you help?
Jun 24, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
JVC home theatre system DVD/CD player has stopped working.
Please check the dvd layer lense. When there is lense problem this issue will occur.
Apr 03, 2009 | Audio Players & Recorders
JVC TH 53 Dvd surround sound system. System locked
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
Feb 17, 2009 | JVC XV-N320 DVD Player
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
No audio from dvd player
you wil get the sound from the surround speakers only but not from tv first connect all the speakers that are given to the player correctly then you can get perfect sounds with dts...
May 04, 2008 | JVC TH-A25 System
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
JVC TH-S8 System Logo
168 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
