Question about H&B HL-3200B-N 32 in. HDTV-Ready LCD Television
H&B LCD TV HL-3200B lost remote
I've been given a second hand one of the above without a remote. Customer support is non existent. I got a sky one for all remote any by a long process of elimination I found the remote code to be 0893. But I still can't access other tv functions such as tuning in terrestial tv etc. Any thoughts on where I can get a proper remote or can you recommend a compatible remote that might be able to do these functions for me?
I LOST MY REMOTE OF H&B 20 L.B.X MODEL T.F.T 000410
http://www.logitech.com/remotes are very good and a dream to set up but it all depends on your budget
May 19, 2012 | H&B HL-3200B-N 32 in. HDTV-Ready LCD...
Need code for polaroid tv for sky
I've posted a clarification request above. You need both the TV model number and the version number of the Sky remote to find the correct code. I install satellite systems - I have access to the entire code database for all versions of Sky remote.
Oct 19, 2011 | Televison & Video
Need an activation code for my sky+ remote to operate the volume on my samsung lcd tv le40s8.
switch to sky on tv and press interactive on sky remote then move down to sky customer service (select) once screen has loaded move down to programe your remote you will need model number and make of tv press select and then enter the make of tv by moving down list once found select and repeat for model then follow on screen instructions
Dec 11, 2009 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Sky TV REMOTE WILL NOT WORK MY LG tv RZ 37LZ55 ,NEED A CODE ....TRIED ALL CODES NON WORK !!
Hello Kenny
Please follow the steps below with you Sky remote.
TV,
RED + SELECT (flashes twice)
TV
0056
Try the volume button if this works then press the SELECT button on the remote. If not press the TV button and try the volume again. repeat this step until the volume works the tv then remember to press the SELECT button to save the code to the remote.
If for any reason this does not work then what I would like you to do is take the battery cover off the remote. You will see a label on there stating what REV 4,6,8 it is. The numbers indicate how old the sky remote is. If your LG telly is a newer tv then you may need to purchase a newer Rev sky remote.
The above should sort you out no Problem Kenny
When it does please leave a thumbs up
Cheers
Little Dish Fitter
Aug 29, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
Onn tv lost channel list after powercut. no remote control, was using sky remote to control sky and tv, now wont work. cannot make sense of button controls-no manual. 37" lcd.
although initialy I was able to operate tv with sky remote, after power cut none of the codes in my freesat information pack would reconnect to tv. On the forum page one of the emails posted said they had been given the code 0527, it hadn't worked for them but it worked for me. My sky remote now operates tv. It does have an irritating habit of always switching to scart 2 at first instead of scart 1where I have freesat, I then have to use the the remote to switch to scart 1 before I can proceed any further. I am happy enough though, I was pulling my hair out before I found your Website.
Cheers
JP
Jun 17, 2009 | iLO 2600 Television
Sky remote control code
Hi!
You can follow the instructions given in the link---
Codes for Sky Digibox
You can also see for reference the instructions manual on the link---
Sky Digibox
You need to just click on the above links and will be able to get the sky remote control code.
Please accept this solution and do rate it as FixYa if found useful.
Thanks
Rylee
Apr 26, 2009 | Televison & Video
Toshiba 2100TB tuning without the remote control
If you are sure, that there's no way to do it manually on the TV, there are only two solutions: buy a new remote control according to your TV set model (sometimes it's hard to find) or buy a universal remote control
Jan 30, 2009 | Televison & Video
Hyundai 32" tft lcd tv. model no.hlt 3270
I don't know if these codes will work but the Hyundai ones we use are code 1272 or 0662.
To put the code in:
Press TV
Press and hold Select & Red until the LED blinks twice
Put in the first code above
press Select
then try the volume buttons, if that doesn't work do exactly the same sequence but try the second code, if neither work let me know and I'll try and find another code for you
Jul 30, 2008 | Hyundai HPT-4250 Television
H&B HL-3200B-N 32 in. HDTV-Ready LCD Television Logo
65 people viewed this question
Top H&B Televison & Video Experts
tony denham
Level 1 Expert
Geoff Dooling
Geoff Dooling
Level 1 Expert
Are you a H&B Televison and Video Expert? Answer questions, earn points and help others
