Question about Goodman GMS807034ANA Heater
Circuit board fuse keeps poping
I am working on a Goodman GMT 070-3 multiposition furnace with central A/C I can run the fan on on , run the heat cycle But everytime I put it to A/C the circuit board fuse pops. Contactor coil on the condensing unit is good. could this board be bad? Is there a way to test the board?
  • HANK MCNEIL May 11, 2010
    I'd bet it's in the 24VAC wiring between the furnace and the condenser or in the condenser.
Traced wires and found the wires to the humidifer were the cuprits. I beleive the solenoid may be no good. After disconnecting the wires to the humidifier, A/C and Heat are working fine now .
Posted on May 29, 2009
Furnace running all the time.
Pull the thermostat off the wall. If the fan keeps running, it is a relay in the board or just an independent fan relay.
Dec 13, 2013 | Goodman Manufacturing Goodman AEPF313716...
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
Aug 14, 2017 | Goodman GMS90703BXA Heater
Goodman a/c @ heating unit. Model #gmh80703anca when I turn the unit on it keeps blowing the fuse on the circuit panel. What could be causing this?
Several questions:
1. What fuse? 110V at the furnace? Breaker at the house? Fuse on the controller board?
2. Does the ignitor work? Do you get gas ignition?
3. Does the exhaust fan come on?
4. Does the main blower come on?
Apr 15, 2013 | Heating & Cooling
The unit has power, but the unit will not run, the fan will not start when set to fan at thermostat
Check inside the furnace for a circuit board. The board may have a small 3 or 5 amp fuse. Check to see if it is blown. The circuit board may have a blinking light to diagnose the problem. The diagnosis scheme should be right on the furnace front panel.
May 30, 2011 | Goodman CKL36AR36 Air Conditioner
Heater keeps going off on its on also fan not
Please provide more info. When it goes off does it come back on by itself or do you have to flip a breaker? Is the furnace gas or electric? If it is not moving enough air across your heat exchanger in a gas furnace or across electric heating elements this will trip a safety switch that will stop heating but not fan. Low air speed is most likely from inexperienced or improper duct design/ installation. Duct sizing is very important to move enough air. Don't believe me try breathing thru a straw. If your unit is a gas furnace it has a flashing code that will tell you what is wrong codes listed inside unit door. Could be lots of things. Reply with more info.
Dec 04, 2009 | Goodman Heating & Cooling
My goodman gas furnace is not kicking on. the light on the unit is saying that it should be working but it is not. there is no pilot light, the fan is working the heat is not
If you are not getting any codes from the board, then the furnace is not getting a call for heat from the thermostat. A wire may have come off, the thermostat not properly wired, or a break in the stat wire. On a call for heat, you should have 24vac between W and C on the circuit board. This will let you know if you are getting a call for heat all the way back to the furnace.
Oct 01, 2009 | Goodman GMS90703BXA Heater
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
Circuit board fuse tripping in cool position
it could be short circuited compressor contactor coil
May 28, 2009 | Goodman CKL42AR42 Air Conditioner
Goodman forced air gas furnace not firing
if your power vent moter is not running you should not have have glowing ignitor.Frist the vent moter must close an air prove switch in series with the idnitor .seems you have a stuck air prove switch.Its the one with a hose attached
Apr 04, 2009 | Heating & Cooling
Furnace start buts shuts off
It sounds like you have an obstruction in the exhaust vent. Thats why when you bybass the pressure switch it runs ok. Steve
Dec 15, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
160 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
