Question about Microsoft Xbox 360 Console
I have two broken 360's, one that randomly freezes and one with the one red light and E 74 error. I need help fixing the scaler chip
I have one xbox 360 that randomly freezes and I can't figure out the problem. I also have another 360 that has the one red light and E 74 error. Please help I'm willing to sacrifice one xbox for the other.
I'll buy them from you.
Posted on May 29, 2009
    Problem Solver:
  • 6 Answers
For the one that randomly freezes. have you treid using it without the hard drive? if yes and it happens to all games then you have to send it to microsoft. if it does not freeze when the hard drive is out then it just have something to do with the memory on certain games or the gamer profile. for the one with e74, if it still has that without the hard drive then you should send it to microsoft nad you have a 3 year warranty for that,.
Posted on May 28, 2009
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
I have the E 74 error how do i fix it?
Basically, this problem is caused by overheating, which is often an issue with most high-powered electronic devices.
As heat levels rise inside your Xbox 360 the connection between the motherboard and the video scaler (HANA/ANA) chip is damaged due to the expansion and contraction of the metal connectors.
Once you have experienced the red ring of death e74 once on your Xbox 360, it will continue to happen over and over again until you fix the problem permanently.
The process of repairing the Xbox 360 red light e74 involves opening up your console, removing the hard drive and disk drive (as these get in the way when you are navigating around the narrow confines of the case) and then locating the video scaler chip.
You then remove it from its seating point and clean the connections; an eraser works well for this. It then has to be seated correctly back in its slot. Once this is done and the hard drive and disk drive are re-installed you can put the case back together.
When you turn your console on again it should be free of the e74 error.
Good Luck and have a nice day.
Jun 07, 2010 | Microsoft Xbox 360 Console
E 74
E74 error is the scaler chip that deals with the display overheating you will need to have it fixed, you can actually do this yourself or you can send it in to have it fixed.
Jan 04, 2010 | Microsoft Xbox 360 Console
I have code error 74
Code E74 1 red light flashing and error message on screen right? It is the scaler chip, it happens because the scaler chip starts overheating. If you stop the heat build up on the chips then you should be fine.
You can send your Xbox 360 back in for repair or fix it yourself with a good Xbox 360 Repair guide
Oct 28, 2009 | Microsoft Xbox 360 Console
Screen reads,system error and has a trouble code of E 74 What could be the problem?
The Xbox 360 e74 error is a rather common problem on Xbox consoles, with similar roots to the now infamous red ring of death problem.
The e74 issue is actually caused by a problem with the scaler (ANA or HANA) chips located next to the graphics processor inside your Xbox 360.
It is believed that the error with the scaler video chip which causes the e74 error on your Xbox 360 is caused by overheating. This is also the cause of other errors such as the no video problem, as well as red lights in the power ring of an Xbox console.
To fix the Xbox 360 e74 code, there are a few steps you need to take-
1. Firstly, leave this article open, go to your Xbox 360 console and then remove the AV cable. Blow any dust out of it, then re-insert it snugly back into the console until a clicking is heard. Power on your console again and see if the problem has been fixed.
2. If that does not work, borrow another AV cable (get one off a friend or family member, or from your local video game rental shop) Try using this one in your Xbox 360.
3. If replacing the AV cable does not work, then you will have to repair the scaler chip and graphics processor inside your Xbox in order to fix the e74 problem. To do this, you will need an Xbox 360 repair guide, which will contain the video instruction files you need to be able to fix your console properly. You cannot fix the e74 yourself without one.
It is important to note that most Xbox repair guides focus on fixing the "red ring of death". However, the process for repairing the e74 will also be covered in the same guide as well, as it is extremely similar.
Aug 28, 2009 | Microsoft Xbox 360 Console
360 error 74 message
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Mar 28, 2009 | Microsoft Xbox 360 Console
On my xbox 360 one red light appears in the bottom right hand corner and on the screen it shows e 74 error
this is a scaler chip problem, a problem with the av cables, or a GPU issue. try borrowing someones av cables, if not, you can try baking the system.
Nov 18, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Error 74
E74 is an error that has two possibilities one is that your AV cable has gone bad. Swap it out and see if that fixs the issue.
If that doesnt work then you need to contact MS, your GPU / Scaler chip has gone bad and MS needs to replace it. There is no fix for this like there is for the red ring error. hope this helps
Jan 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
125 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
