Question about Sharp Office Equipment & Supplies
Lcd pisplayed rcv NSF CSI DIS snd TSI DCS ICF
Please tell me what's problem this sharp FAX mashine FO-51. LCD displayed "rcv NSF CSI DIS and snd TSI DCS ICF"
  • 215 Answers
SOURCE: TONER LIFE END APPEARS ON LCD
try opening front door, press "options" then "start" then "1" and "0". if screen shows accepted, you're good to go. close front cover.
hth,
razors
Posted on Feb 06, 2009
  • 37 Answers
SOURCE: Clearing LCD Screen from RECOMEND NEW CRT
if u refill it may can't remove that message but try to press stop button for 5 sec to clear it
Posted on May 23, 2009
  • 48 Answers
SOURCE: sharp fax model fo 2950m
There are two ways to fix your problem. First open your cover, then press the small white rounded reset button in the lower frame. The second method - unplug your fax, then hold down the stop and start key while pluging in the fax. When you see memory clear on the screen let go of the stop and start key. I believe the screen will say 1 for yes 2 for no for memory clear, press 1. The second method will ERASE every thing in memory that includes program #'s and transaction report setting.
Posted on May 25, 2009
SOURCE: Canon Laser Class 9000 Super G3 Plain Paper Fax
I bought a Canon FaxPhone Super G3. I was told I could set the machine so that whe I send a fax from the machine, the machine can send a copy to an e-fax number. If possible, can you please explain how to do this?
Thanks,
Raul
Posted on Jul 08, 2009
  • 66 Answers
SOURCE: Sharp FO-P610 Have mislaid manual and need setting to use answer
tel fax
Posted on Nov 16, 2009
Testimonial: "Excellent response thank you"
Sharp FO-2081 clear memory full
enter simulation mode using # * c * after you are in run test command 66-10
Apr 08, 2014 | Sharp FO-2081 Copier
Display is too faint
One of the drawbacks of LCD displays is that they can fade with age. If you have an older fax machine, this may be the cause of the fading
Feb 23, 2013 | Office Equipment & Supplies
My fax machine is recognizing my home number which is line 1 in our house. I need it to recognize line 2
No fax machine holds your address. You can enter your fax number which is called the csi (caller station ID) and your Name (ie company name) called your TSi (transmitting station ID). thats all. Some machines will let you have multiple TSI's for different departments. I have never in 25 years on working on faxes ever heard of one holding an address!. The maximum amount of digits you can enter ranges from 15 to 30depended on make and model.
Srri
May 15, 2011 | Canon Office Equipment & Supplies
My fax can receive but is unable to send. Message is COMM ERROR 2
Your machine failed to communicate diring the initial protocol. This is the handshake that tells the receiving fax that you are what you are. IMPORTANT Check that your fax ID is entered in the fax, as some countries require that if it is not present to reject it. This can also be set on any receiving fax to reject junk fax. So Both the TTI and the CSI must be entered in your fax to work.
Oct 06, 2010 | Sharp FO 760 Plain Paper Thermal transfer...
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
How do you send a fax with a fo 760?
It asn't my fax, I as doing it for a freind. I own mainly HP products and I gotta tell you the online help from HP is very good, after tying to find out just how to fax a peice of paper from sharp I would never buy a sharp machine.Regards Paul.
Dec 14, 2008 | Sharp FO 760 Plain Paper Thermal transfer...
LCD display invisible on Sony ICF-2010
I found a posting that said this usually is a problem with weak memory batteries or a bad battery contacts. I replaced batteries and cleaned contacts and the problem was solved.
Mar 09, 2008 | Sony ICF-2010 AM/FM/SW Radio
Problem in work off faxmachin
now lets practice good grammar and speak proper english. unplug and replug printer. Otherwise, get a new one.
Mar 07, 2007 | Sharp UX CC500 Plain Paper Thermal...
178 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
