Question about AEG B1180-4 Electric Single Oven
Diplomat 050502078 or ADP 0150 Grill not working
Hi There
As usual a new flat with no oven manual! (any idea where I can get one?) The ignition for the grill makes a loud clicking sound and I can smell gas but it is not igniting. There is a small spark. ARe the gas jets blocked??? Murphy's law it worked ok when the landlord tried it!!
Any help greatly aprreciated! Rochelle
5 Suggested Answers
  • 1462 Answers
SOURCE: B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Posted on Mar 26, 2007
  • 26 Answers
SOURCE: My large main oven will
Is the clock set? The display must show the correct time and must not be set to automatic cooking.
If the light comes on and the fan is working then the clock is set. If there is no heat then the element behind the cover and surrounding the fan is probably open circuit. This can be accessed without needing to remove the oven from the carcass.
Good luck
Posted on Nov 27, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Posted on Jan 27, 2009
  • 77 Answers
SOURCE: i have a diplomat adp 3120 and i vant put the
could well be the grill element blown.
Posted on Mar 20, 2010
A manual for a diplomat high level oven and grill, model number 200504035 adp0312 please
I'd suggest contacting UK Whitegoods. They still carry spares for the Diplomat line, they may have manuals available for download.
Otherwise, manuals.com
Jan 04, 2017 | Ovens
How do you reset the clock on a Diplomat HJA 3300 oven? Would you by any chance have a pdf of the manual?
Press and hold the timer and casserole symbol buttons at the same time then press or - to set the time. If "auto" flashes you will have to cancel that programme.
Feb 25, 2011 | Ovens
Need a user manual for a Hygena diplomat oven model AHY 3420 any ideas please?
I have a manual for AHY3420, it's a very generic manual which covers different ovens. I am happy to send you a scanned copy if you send me an e-mail address.
I have the same oven and all the symbols have disappeared on the third dial (the one which switches on the oven), so I still haven't worked out which setting does what - I can just about make out a grill symbol, but that's about it. Is there any chance you could tell me what the symbols are on the 3rd dial?
Thanks very much.
Sigrun
Feb 10, 2010 | Ovens
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Hi need a manual for a select 920 diplomat oven
I have a Hygena 920 twin oven and grill .The electrical element in the grill started to droop several months ago, now it has stopped working . the element has burnt through. Could this have caused a fire?
I should like to know if it is possible to get a spare element and fit it myself. What would be the cost of the element? Thanking you in anticipation.
Mr J. Walden
Sep 02, 2009 | Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
AEG B1180-4 Electric Single Oven Logo
181 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
