Question about Princeton Digital VL1916 19" LCD Monitor
Os-winxp the screen flickers on and off
  • 10,515 Answers
I had that same problem with my 17 inches LCD monitor. The problem why it
does that is due to the video card having trouble to catch up with the LCD
monitor. I set the mhz on the video card to 75 hertz and the problem went
away. set your LCD monitor at 1280 x 1024 and you won't see the flickering.
Sometimes, It is the video card that is causing the problem or interference from
magnetic waves in the house.
Thanks for using Fixya.
Posted on May 28, 2009
I am running win 7 & when tried to install xp its showing compatibility problem . pl reply
Remember.... the OS compatibility is only lower to upper...not upper to lower....i.e.....
Win7 is higher than WinXP....so u cant run / install WinXP using Win7...but u can do the otherway round....i.e...1st u can install WinXP in C: drive, then let the machine start, once u get to WinXp dekstop then install Win7 in D: drive...(it's called Dual Boot)...so on the boot screen u can choose which OS to work with when the PC starts....
all the best
pls revert back...and kindly leave a rating and feedback to this solution...it will help me become a "Guru" here on Fixya....
regards...
Sep 29, 2010 | Computers & Internet
How do I repair a toshiba m305 that has a flicker at the bottom of the screen
Unplug AC Charger. Kindly check the bottom part of the display if it still flickering while the ac adapter is unplugged. If system stops flickering issue was due to unstable charger, you may need to reseat the power cord or maybe replace the ac adapter itself.
On the other hand if display still flickers after you disconnect the charger kindly reinstall the display
driver. Since I don't have any idea what operating system youre using right now, I put all the link for all the available os for the graphic card driver.
For windows 7 (both 32 and 64 bit) Click here
For Win vista os with Intel Graphic card Click here.
For Win vista os with ATI Graphic card Click here.
For Win XP os with Intel Graphic card Click here.
Make sure to restart the computer after the installation. If same problem occured, please contact the computer manufacturer to have the video card replaced.
Should you have any other questions please leave a comment.
Cheers~
Jun 21, 2010 | Toshiba Satellite M305-S4826 Laptop
Error message on blue screen
corrupt HD and OS....reformat HD and install OS, boot from CD rom after inserting the WinXP disk
Feb 19, 2010 | Dell Inspiron 1501 Laptop
HP 6735s laptop with AMD Turion X2, screen remain dark...
Try locating your memory sticks under unit, try taking them out and resitting them, try also resitting your hard drive.
if this does not work let us know
Jan 04, 2010 | HP Compaq 6735s Notebook
Display is flickering and goes out and the screen become black. I attempted to hook up external display and get the same results. I think the issue may be a bad inverter card? System has winXP Home...
try tapping the LCD bezel, if you sense that the LCD would flicker, your hunch might be correct about the bad inverter card. it would also depend if the LCD type has an inverter. or worse case scenario - LCD is already failing...
Hope it helps!
Oct 26, 2009 | Gateway MX3215 Notebook
I have HP laptop with Windows OS.Can I ADD Windows XP OS?
yes you can install winxp if you have winxp bootable disk.
Boot your computer with winxp disk.
For that insert winxp disk into cd or dvd rom then when you power up press F8 or F5 or F12 to get first boot option then set first boot as your cd or dvd rom then you can boot computer with disk.
Jul 29, 2009 | Computers & Internet
I cannot install OS winxp onto sata drive pc is Acer aspire x3200
There could be two reasons for the blue screen either a bad harddrive or loose memory cards in the slots. Try reseating the memory cards on the motherboard.
Also please post back the Stop code you are getting on the blue screen
proton
Jul 27, 2009 | IBM SYSTEM X3200 M2 E4600 2.4G 2GB 2MB...
Dual boot prob
boot to win98 operating system. Insert the XP operating CD. IT will automatically open a window asking you to select Install winXP prof. It will ask for new installation and Upgrade (recommended)
select upgrade and select next and follow the instructions. it will restart and ask you select the os.
select xp in blue screen. install the OS other than C Drive.
please don't ever install in c drive.. do with caution.
Enjoy.
Oct 19, 2008 | Computers & Internet
Booting slow in os
You need to edit the Boot.ini file to do that.
Here's a link that will guide you on how to remove those extra boot options:
http://support.microsoft.com/kb/289022
Nov 20, 2007 | Computers & Internet
Princeton Digital VL1916 19" LCD Monitor Logo
120 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
