Can not scan
Can't scan and when access Hp solution center the error message appears "No Hp devices has been detected, Hp Solution center will close now"
  • 70 Answers
The scanner driver is not installed on your computer you have to install the driver for your scanner with the cd that was given to you while purchasing the scanner
Posted on May 28, 2009
"No Scan Options - Refer
There is a 'white paper' available on HP's website that specifically addresses this error message. I'm providing the link for you that will take you directly to that page:
http://h10025.www1.hp.com/ewfrf/wc/docum...
Please read it and maybe print it out for reference... it explains what you need to do and THE ORDER you need to do it in. This should solve your issue...
Good Luck!
bhupi
Apr 19, 2011 | Office Equipment & Supplies
I have a hp psc 1410 all in one printer and when i starting to scan a document or a picture ,an error message appears that saying an error occurred communicating with the scaning divise. Please ensure that...
Try this simple step first,
Disconnect the Power cord from the back of printer (while printer is on)
Wait for 10 seconds,
Connect the cord back and wait till it initializes.
Close HP Director or HP Solution Center,
Try to Scan, It should work.
Jul 06, 2010 | HP Office Equipment & Supplies
HP CUE-SCANNING FLOW COMPONENT MESSAGE EACH TIME I TRY TO SCAN A DOCUMENT
When you have the Error on the Screen - Dont close it
Click START - Click RUN - Type SERVICES.MSC - Click ok
You will find
HP Cue Device Discovery in the list - doubt click and click Disable
HPQSCX08 - Double click and Click Disable
The Error should Disappear. Close Solution Center and Re-open and try Scanning.
Jun 23, 2010 | HP DeskJet F4280 All In One Printer InkJet
HP Photosmart 3110 All-in-one - Scanner function not working
Scanning requires two-way communication between the computer and the scanner. Usually the error that you describe above indicates an issue with the USB connection. First, make sure that you are not using a USB hub. Try a new USB 2.0 (A-B) cable that is under 6' long. Try using a different USB port on the computer.
If the problem persists, check the Device Manager to see if you have a USB driver problem. (For most versions of Windows, press the Windows key + X to quickly access the menu with the Device Manager.) Expand the section labeled Universal Serial Bus controllers and look for an exclamation point or an X. Similarly check for any issues in the Devices and Printers section of the Control Panel. The All-in-One should be listed as a printer and a scanner.
I hope this helps. If you are still having problems, please add a comment with the OS version on your computer. That can help identify additional issues that could be involved.
Apr 04, 2017 | HP Photosmart 3110 All-In-One InkJet...
HP Deskjet F4280 scanning problem
reload the whole HP software package in this PC
no PC stated nor full model number
no OS stated, what Op sys is it windows 10>? what/?
why not ask hp this. on there forum , warning the same questions will be asked, or all answers will be wrong
ask here, REAL HP, we are not HP here, we are chat box (dumbb)
https://h30434.www3.hp.com/
Aug 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
HP Solution Center No HP Devices Detected
Try this
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP DESKJET F2100
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Thanks
Riz
Jan 03, 2009 | HP Photosmart C8180 All-in-One InkJet...
No HP devices detected. HP Solutions Center will close now.
HP PSC, Officejet, and Photosmart All-in-Ones - The Error Message 'No HP Devices Detected' Occurs When Opening HP Solution Center (c00762521) Issue gtabtop.gif When opening HP Solution Center, a message appears that states "No HP Devices Detected ".
    Solution one: Check connections and status
    1. Check to make sure that the device cables are connected securely at each end.
    2. Make sure the device is turned on and not in an error state. If unsure, turn the unit off and then back on again.
    3. Try to access the device through Solution Center again.
    4. If the device is still not detected, proceed to Solution two.
    Solution two: Check that there is a printer icon in the printer folder
    1. Click Start and then Settings or Control Panel .
    2. Click Printers or Printers and Faxes .
    3. Make sure there is an icon for the printer you are trying to use.
      • If there is no icon and you are connecting via a USB cable, disconnect the cable, and restart the computer. Reinsert the HP software CD and choose Add a device . Connect the unit when prompted by the installer.
      • If there is no icon and it is a wireless connection, run the wireless setup wizard as outlined in the product setup guide, then reinsert the CD and choose Add a device .
      • If there is no icon and it is an Ethernet connection, reinsert the CD and choose Add a device .
    Solution three: Check that the Digital Imaging Monitor is running
      NOTE: If you chose a custom install and did not select HP Digital Imaging Device Functions, the Digital Imaging Monitor will not be installed. Proceed to Solution five.
    1. Press the CTRL , ALT , and Delete keys at the same time to open the Task Manager.
    2. Look to see if HPQTRA08 and HPQSTE08 are running.
    3. If they are not running, restart the computer and then try again.
    4. If they are still not showing in the list, proceed to Solution four.
    Solution four: Check that the HPZPML driver is running
    1. In Windows XP and 2000, click Start , Control Panel , Administrative Services , and then click the Services Icon . Scroll through the list looking for HPZPML to make sure it is set to automatic and that it is running.
    2. In Windows 98/ME, open the Task Manager by pressing CTRL , ALT , and then Delete . The file HPZIPM should be listed.
    3. If the HPZML or HPZIM file are not available, restart the computer. If they still do not show up, proceed to Solution five.
    Solution five: Uninstall and reinstall the software
    1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
    2. If the software installer does not automatically start, complete the following steps:
      1. Click Start and then Run .
      2. On the Open line, type D:\SETUP , where D is the letter of the CD-ROM drive.
      3. Click OK .
    3. Click Uninstall on the installer screen. If Uninstall is not an option, the software installation was incomplete. Click Install .
    4. Follow the onscreen instructions until the printer software is completely installed.
Causegtabtop.gif There are several reasons this can happen. The device was not connected during the installation of the software, there is no printer icon in the printer folder, the Digital Imaging Monitor is not running, or the HP service PML driver is not running.
Aug 18, 2008 | HP Photosmart 3210 All-In-One InkJet...
Can't scan from printer or computer
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1. HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run Digital Imaging Monitor.
◄ Wait for a Minute, if the configuration screen appears it is done else refresh the HP Cue Device Discovery
◄ Restart the Printer
◄ 99% chances of resolution and in the other cases a proper uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
May 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
