Question about JVC LT-26C31 26 in. LCD Television
Sound no picture
Hi i have the jvc lt26c31 and from cold when turned on will be great sound and picture perfect the set will stay perfect all the time its on but if turned of will only give you sound no picture. any help would be greatly appreciated
  • 3 more comments
  • jonesy69 Nov 15, 2007
    every time i turn on the tv we have sound but no picture.turning the tv off and on a couple of times brings the picture back.once the tv is on with sound and picture it will remain fine until turned off again. any thoughts????
  • Anonymous Dec 30, 2007
    Same problem - sound but no picture. Gradually took longer and longer for picture to appear. Until finally, the picture wont generate at all.
  • didz Jan 12, 2008
    email address is if you could send me a pic or more info that would be great thanks
  • Anonymous Mar 21, 2008
    We have exact the same problem. we have sound but no picture. Houw do we get the picture back again? The tv is only four years old!!!
  • aube Nov 29, 2008
    same problem, sound ok but no picture, sometimes the picture comes, resolder the two chips on the digiboard brings no effect
  • 3 Answers
Take back off lie flat
where the hd leads go into that board remove the screws at the top and bottom as its one long unit top to bottom
unscrew metal shield as well
remove all cables from board 2 ribbons are locked and require clipping down then ribbon removes
flip board over remove metal can to expose board notice 2 TSOP chips at top look att the pins one should look dull and not shiny
to fix i used heatgun a quick blast on pins sorted problem out
mask off board and chip around with metal etc... to not damage board.
Posted on Nov 15, 2009
Hi same as solution 3 put took two chips out bent leg s down and replaced so far work like new
Posted on Jan 28, 2009
Disassembled my unit today. On the suggested digital board, there are a lot of surface mounted chips. The 29LV400 flash memory chip looked bad soldered under the magnifying glass. Resoldered the chip and voila the unit is working like new.
Posted on Aug 19, 2008
Can u send me a picture of this chip that needs soldering many thanks
Posted on Jan 12, 2008
I can tell you the soloution its the digital board has a chip on there that needs to be cleaned or soldered directly to the board for the problem to be sorted for good
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
Jan 27, 2018 | LG Televison & Video
Screen goes blue and returns if cable cord moved
try do the same thing using the dvd or cd player plugged in.
Oct 21, 2008 | JVC AV-36890 36" TV
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
I recently bought a JVC KD-R311 car stereo, its a great stereo but my settings dont save, for instance i set the perfect sound adjusting bass/treb/mid/loudness and whenever i turn my car back on after...
You need to have the yellow wire from the stereo connected to constant battery/12 volts. That wire supplies power for the memory, if it is connected to ignition power, when you turn off the car, the power for the memory is off also.
Jvc televison
did u try to press menu? did you see any txt? if not, try turn it on for 1 min. and turn it off for 5 mins.remove other electronic material near tv set, like speaker etc..
Jan 01, 2008 | Televison & Video
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
JVC AV-27530 27"
Dec 03, 2007 | JVC AV-27530 27" TV
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
JVC AV-27820 27" TV
probably some cold solder joints. take your time and check over whole circuit board and re-solder what looks bad.
Jun 10, 2006 | JVC AV-27820 27" TV
Open Questions:
JVC LT-26C31 26 in. LCD Television Logo
814 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
