Question about HP Pavilion ze4315us Notebook
Can't Get to Motherboard
I can't quite get the ze4315us Laptop apart.  I have all of the screws I can find removed but am still attached at center of laptop.  Here is a snapshot of the problem looking down the hard drive slot.
The attachment(s) I need to release is in the area of the hard drive plugin at the end of the slot.  The post to the immediate right looks like (a part of) the problem.  How do I disengage the "keyboard" plate from the base so I can get to the motherboard?
  • bobhintz Oct 22, 2007
    It's a little more complicated than that but giving me the URL of the service manual pdf file is mana from heaven.  It gives me step by step instructions on how to remove the mother board which is what I need to do to get to the dc jack on it.  Thank you very much.
  • 104 Answers
Removal Procedure
1. Unplug the AC adapter, if present, and then remove the battery.
2. Remove the two M2.5×4.0mm hinge cover screws that secure the keyboard cover to the rear
of the notebook.
3. Carefully insert a flat-blade screwdriver blade under the keyboard cover near the right end, then near
the center, then near the left end, and then gently lift up the center of the cover. Gently pry up the hinge
covers if needed, being careful not to damage the plastics or wireless antenna underneath
The hp manual is here
Posted on Oct 21, 2007
How do i safely remove the cable that attaches to the motherboard on my toshiba laptop
Toshiba satellite motherboard removal.
A motherboard is usually replaced for one of two reasons. You either replace a motherboard because it has gone bad, or you replace an older motherboard with a new or upgraded motherboard. In either case you will have to completely disassemble your laptop to even gain access to your motherboard. Fortunately, the Toshiba Satellite laptop can be completely disassembled even if you don't have a lot of technical knowledge.
Turn off the laptop, disconnect the power cable, remove the battery pack and disconnect any miscellaneous cables and peripheral devices. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an antistatic wrist bracelet to prevent shock from static electricity. Static electricity can harm your computer's internal parts. Place the laptop face down, and remove the single Phillips-head screw attached to the hard drive cover. Remove the hard drive cover, then set it aside. Remove the single Phillips-head screw attached to the wireless card/memory cover. Remove the cover and set it aside. Slide the hard drive out of its compartment. This will disconnect the hard drive from the computer. Set the hard drive aside very carefully. Push on the ejector tabs on either side of each RAM module. Slide the RAM modules out of their compartments at a 45-degree angle. Remove them from the laptop and set them carefully aside. Disconnect the antenna cable from the wireless card, and then lift the wireless card out of the laptop. Remove the four retaining screws from the modem card. Lift the modem card slightly out of the laptop, and then disconnect the modem cable from the motherboard. Set the modem card aside. Remove the single Phillips-head screw securing the DVD/optical drive. Slide the DVD drive out of the laptop's frame and set it aside. Remove all marked screws from the bottom casing of the laptop, and then place the laptop face up. Open the laptop as far as it will go. Use a small flathead screwdriver to pry up the keyboard bezel. The keyboard bezel is a small plastic strip sitting between the keyboard and the LCD display. Remove the two Phillips-head screws securing the keyboard in place. Lift up on the keyboard and disconnect the keyboard's ribbon connector from the motherboard. Remove the keyboard from the laptop and set it aside very carefully. Close the laptop. Place the laptop vertically so the LCD display hinges are face up. Remove the two Phillips-head screws from the hinges. Set the laptop down and open the laptop as far as it will go. Remove the four Phillips-head screws securing the LCD display. Lift up on the LCD display, and then disconnect the video cable from the motherboard. Remove the LCD display from the laptop and set it aside carefully. Disconnect the DVD control board cable, the touchpad cables and speaker cables from the motherboard. Disengage the plastic latches on the rear of the laptop casing near the hinges, and then remove the top casing from the laptop's base and set it aside. Remove the two Phillips-head screws securing the CPU fan and heat sink in place. Disconnect the fan cable from the motherboard. Remove the fan and heat sink from the motherboard and set it aside. Remove the single Phillips-head screw securing the motherboard to the bottom laptop casing. Disconnect the USB port connector from the motherboard and remove the jack from its housing. Lift the motherboard from the bottom laptop casing and very carefully set it aside.
Hope this helps.
Dec 13, 2012 | Computers & Internet
How do I take my toshiba sattilite laptop apart? I spilled milk on it.
Ok, on a laptop you need to get some cups and label them toput the screws in so you will know where they came from. Remove the PowerCord, Remove the Battery then start removing all thescrews from the bottom of the laptop. Then remove all the devices fromthe bottom of the laptop such as the hard drive, the memory, dvd/cd drive,wireless card, etc. Take note of how the wires are on the wireless card,those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slotfor screw. Some screws on the bottom case in inside of some of the devicecases might have the icon of a keyboard next to it. Those screws hold thekeyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
Jun 07, 2012 | Toshiba Computers & Internet
How to change a cmos battery in a transport gx2 notebook?
You'll have to take the laptop apart to get to the cmos battery in most cases. It will be a silver battery about the size of a nickel on the motherboard. The most common size is CR2032. Also sometimes the battery will be in a vinyl covering and have a cable that attaches to a port on the motherboard. Which ever type you have you'll need to either remove the battery or unplug the cable and let the laptop sit for an hour or two. Then put it back, reassemble the laptop and reboot the laptop. With the CMOS battery out the computer will lose the date, time and password on some older models.
Ok, on a laptop you need to get some cups and label them to put the screws in so you will know where they came from. Remove the Power Cord, Remove the Battery then start removing all the screws from the bottom of the laptop. Then remove all the devices from the bottom of the laptop such as the hard drive, the memory, dvd/cd drive, wireless card, etc. Take note of how the wires are on the wireless card, those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slot for screw. Some screws on the bottom case in inside of some of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but be careful because a cable might be attached to it. Then remove the screws that hold the keyboard in place that are under where the strip was and gently lift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift the lcd screen off, also note that you will have to pull the antennas cable and the lcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note of any cables that are attached to the palmrest and remove them then lift the palmrest off.
Next start removing any screws you see that hold the motherboard to the bottom case, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory of where things were.
Jun 06, 2012 | MPC Computers TransPort GX2 Notebook
Cooling fan quite working on nv55c
May 24, 2012 | Gateway Computers & Internet
How to Replace the HP Pavilion dv7-4270us Fan
You will have to take the laptop apart to get to the fan.
May 10, 2012 | HP Computers & Internet
Dissamble asus ulcpc to access power supply
LOL, You need detailed instructions on how to disassemble a laptop? You do of course know that every model is different, right? Instructions would have to be high level or it would take a book to give you details. If you don't know what you're doing I suggest you take it to a computer repair shop. Actually taking the laptop apart is the easy part for the task you want to do. The hard part is desoldering the dc jack that is already on the motherboard and then soldering a new one in it's place. Desoldering and getting the old dc jack out is a task and if you put too much pressure on the motherboard you could crack it or break something off.
So to take it apart you take all the screws off the bottom of the laptop, remove the hard drive, remove the cd drive, remove the battery, remove the wireless card, remove memory. Some of the things we just removed might be secured with screws and some of them once they are removed will surely have screws that were under them that attaches to the motherboard. Then you have to turn the laptop over, remove the piece that is right above the keyboard that normally has the power button on it. Be careful, sometimes there is a cable attached to it. Then you remove the screws that hold the keyboard and carefully pull the keyboard out because it most definitely has a cable under it. Then you remove the lcd by removing screws from it's hinges, and remove the cable that plugs into the motherboard and carefully pull the wifi cable that runs from the lcd, then down under where the keyboard sat, and through a slot that gets it to the bottom of the motherboard. Once you remove the lcd, you start removing screws that hold the palmrest to the motherboard and when you lift the palmrest be careful because there are cables such as the mouse and touchpad under it. Then you start removing screws that have the motherboard attached to the bottom case. Once they are removed you can lift the motherboard out but be careful because there will be other cables attached to it that you'll have to take off such as the cpu fan cable, etc. One you have the motherboard out you might have to remove the heat sink and fan that is secured by screws and the head sink has a coat of Thermal Paste on it that you'll most likely want to replace otherwise you have the risk of overheating. Once all that is done, now you have to start desoldering to pull the old prongs out that was holding the dc power jack to the motherboard (this part alone will take well over an hour), Then pop the new jack in it's place and start soldering it. Then pray to God, Allah, Buddha, Jehovah or whoever it is you serve that you can put it all back together and that it works!!!!!
Mar 22, 2012 | Computers & Internet
The connection where you plug in the power on my compact presario R3000 laptop is broken. The female part that you plug into is loose and probably broken away from the solder on the mother board it self. I...
Before you pull apart your laptop, check the male connector and power cord of the adapter, check it with a multimeter and or plug it into another Compaq. You could have a broken wire in the power cord, it could save you a lot of work.
To pull apart the laptop, remove the battery, hard drive and CD drive first.
Then remove all the screws from the bottom of the laptop, plus the screws on the back that holds the LCD's hinge to the laptop base.
Take a note of where the screws come from, some may be shorter that others.
The remove the keyboard (the screws should already been removed from the bottom of the laptop).
Carefully remove the plastic cover next to the base of the LCD screen, This may also cover the hinges, if necessary fold the screen flat to enable you to carefully pry this cover up and off.
The plastic top cover is clip fastened to the bottom of the case, carefully prize apart from one side and gradually work around the other sides.
You can now remove the LCD, there are two connects attached to the motherboard, unclip these.
The motherboard is under the keyboard and plastic top cover, there are screws securing it to the plastic base, remove these and you should be able to free it from the base.
Now you can solder/fix the power connector.
I suggest you use a temperature controlled soldering iron.
Don't use too much force, you might crack the plastic parts.
Best of luck and have fun.
Jan 12, 2009 | Computers & Internet
Video card screwed on presario v3000 (known issue)
The mainboard or motherboard is the main PCB in the laptop. It is the most difficult component to replace because you must completely disassemble the laptop to remove it and properly install the new one. Take the battery out, ground yourself and discharge the laptop by pressing the power button for a few seconds. Most laptops start dissassembling by removing the power button/led panel above the keyboard, and then removing the keyboard, de-attaching the LCD screen assembly. And then flipping it over and removing screws on the bottom, then the laptop will split in two peices, the top part of the chassis and then the bottom half which is where the motherboard will be attached. If you decide to continue organize your screws, label them or take pictures to help you get it back together. Hope this helps you get started.
Dec 16, 2008 | HP Compaq Presario v3000z Notebook
Flash bios crash
The only 2 way to fix it is to replace the motherboard or:
Take the computer apart by removing all visible screws. And slowly and carefully removing all parts. Start with screws under keyboard on bottom of chassis. After you remove the keyboard you will see more of a hint to get the laptop apart. Go to tomshardware.com and search the site for how-to on disassembling a laptop. After you get it open you should look for your bios chip , the picture is attached here. If it is socketed you can get the numbers
and do an
 internet search or call acer and get one from the manufacturer.
Here is one for a toshiba laptop: http://www.irisvista.com/tech/laptops/Toshiba_Tecra_S2/pull_apart_laptop_1.htm</url>
Jan 07, 2008 | Acer Aspire 5100 Notebook
Replace Damaged AC Power Jack
I have replaced alot of jacks in similar models as this one.
I don't have one in front of me, but, assuming you have removed the power button/hinge cover plastics, removed the lcd, removed the keyboard and then removed the palmrest plastics.... you now have a base with the motherboard still in it. There are a few screws that attatch the motherboard to the bottom black chassis. Just have to carefully look around the board for them and remove them. Also, might need to remove the lugs on the back where the video connector and paralell port is located. And disconnect a couple wires here and there.
If you had pics available, I might could be of more help. Trying to get a mental picture of what your talking about. I have taken apart alot of these, and can usually get one down to a bare mainboard within 5 minutes easily.
Are you still needing help with it?
Oct 20, 2007 | HP Pavilion ze4315us Notebook
HP Pavilion ze4315us Notebook Logo
142 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
