Question about Maytag HYE3658AY Electric Dryer
A dark residue inside of dryer
We cleaned dryer once because there was a dark residue on the inside of dryer which turned whites gray.   We cleaned with an oil base soap like Ponds and the film came right off.   Also a dark, tacky small spots are around the rubber seal around the door (mostly on the bottom). What would cause this color change inside the dryer?   Is it the clothes with a rubber backing, certain synthiques,dyes, types of soaps or is there a filter needing to be cleaned?
Thank you for your time and consideration,
For Maytag HYE3658AY Dryer there is a metal screen on back circular wall inside where tumbler is located. There are two torsion screws that appear to hold metal screen. If you remove these two metal torsion screws will you be able to clean this aluminum screen/filter?
Thank you sea breeze for your possible solution! We found inside the lent filter catch small black oil based pieces. When rubbed between the fingers it leaves an oily film like sot.
Sincerely grey mess
Posted on Nov 04, 2007
  • Maytag Master
  • 4,655 Answers
Sounds like an ink pen was left in the clothing during wash and leaked out when put in the dryer
Posted on Oct 22, 2007
White Residue on black clothes after cycle
If the FILTER is not cleaned after each load was completed this will happen.
Mar 01, 2014 | GE Washing Machines
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
Mar 05, 2011 | LG DLG5988 Gas Dryer
White residue on black clothing
I am sure you did not wash dark clothes with white, right?
How old is the washing machine?
Do you feel/see any white particles in the basket of the machine, when the cover is open, and it dries out inside?-- when you wipe your hand inside (the dry machine), do you pick up white residue?
What type of soaps are you using?-- any chance they could be causing the residue?
How hard is your water? (Do you have a water softener in the water system?
Please tell us more about your circumstances.
Mack B
Dec 28, 2010 | Washing Machines
Clothes are left with a residue on them. I use
Do you use a liquid fabric softner also ? Marks are usually left on clothes from undisolved fabric softner . Try using dryer sheets instead of washer softner .
Jul 16, 2009 | Washing Machines
Black carbon/soot on the door and lint filter of my dryer
Soot would mean lint is circulating around in your machine, and getting to the combustion area. Take the machine all apart and clean it thoroughly, including taking the cover off the fan and cleaning it too. A dirty fan will slow down the whole works. Check with your hardware store for a chimney-sweep's brush. I once bought one that could be tied to ropes and pulled up and down a flue. If they have a brush the right size, you could do that and really clean your dryer vent.
May 12, 2009 | Crosley CDG6000 Gas Dryer
Leaves white clothes gray
Many of the machines are having a similar issue I am trying to find a resolution to fixing this, there are two issues. First Whirlpool has just recently identified a problem with premature bleach dispensing. Another dispensing problem I had is that fabric softener had to be diluted otherwise it would not wash out of the dispenser. And finally, the fabric softener dispenser would still hold a small amount of water after the wash cycle completed.Removing the top of some washers I have found that there is often a lot of stainless steel polish residue around the rim of the machine - which should have been cleaned away before the machine was shipped from Whirlpool. The gray, oily residue was not visible without removing the top of the washer. Knowing now what has caused the dark gray streaks on many peoples laundry.
Feb 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Dryer turns white clothes gray.
Replace Burner.
I have the same problem, getting ready to try and tackle this. I've been told it is the burner that is the problem, a crack or cracks in the burner are letting the soot into the drum instead of venting to the outside.
Dec 29, 2008 | Dryers
Black residue inside gas dryer
r u on lp gas or nat gas if u r lp gas u need to convert the burner from nat gas to lp gas u need to call your gas co. to do the convertion
Dec 13, 2008 | Maytag Performa PAV2200
Maytag HYE3658AY Electric Dryer Logo
342 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
