Question about Lands Phones
I can make calls, but when people rings me , it gives a busy tone. Its not bared or locked, or has a low battery.
  • 10,515 Answers
This is not a mobile problem. This is actually a network problem. No doubt you are making calls, However if they are unable to call you, there has been a fault in network.
You need to call the service provider. They might take 24 hrs for it to rectify.
Note - I am taking into consideration that your mobile is not at fault. ( Hardware fault )....
Thanks for using Fixya.
Posted on May 28, 2009
Why can't I rec or make calls?
What is happening when a call comes in are they getting a busy signal? If so your line is shorted out.. unplug all phones and see if caller hears a ring.. Then 1 at a time plug phones in. Check for a dial tone and press a digit, hang up and check and see if dial tone returns, repeat this on all phones, until you get to the phone that does not give you dial tone back after dialing a digit. That will be your bad phone... If the line was ring busy after all phones unplugged, call repair service..
Aug 10, 2015 | Lands Phones
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
Mar 14, 2011 | Nokia 2310 Cellular Phone
I need to Know how to use? when i install this cant take calls & i am calling from another phone heard busy tone not ringing
The phone is like a landline phone so that means the there is network failure so you have to hold on for the network to be full restored for it to give you an enageing tone
Feb 09, 2011 | Panasonic KX-TG1100 Cordless Phone
No dail tone cant call out , and try to call in ,line give busy
Is there dial tone at the base unit? You likely will need to replace the battery ...
Jun 19, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
I cannot call out on my KX-TG9331T. Coming in calls ring busy
Try switching batteries with one of your other handsets known to be in good working order or replace the batteries in the handset with the problem with new ones
Apr 20, 2017 | Panasonic KX-TG1033S Cordless Phone
Phone loock code alfatel h1
the phone lock code for alfrtel phone is 1122
Feb 20, 2009 | Handmark Software MobileLists (950142) for...
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
KX-TG 5632
maybe you have un read mail message, or the battery has less power inside, or eitherthe line is down.
Jul 14, 2008 | Panasonic KX-TG5632 Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
