Question about Linksys Wireless-G WRT54G Router
Router disappeared as an option on my computer
My wireless went down after a power outage.  The router is plugged into a power strip and gets power but both my husband's and my computers don't register our router as an option for connection.  I've tried the reset and the unplugging/plugging back in.  Any suggestions would be apprecaited.  thanks.
    President:
  • 2,961 Answers
If all the light are on then the router is working, any flashing other than the wireless then refer to the manual.
Go to control panel>network connections, right click, then properties, then click the TCP/IP line, properties again and ensure that 'obtain ip address automatically' is ticked, click ok,  then close down the window, right click on the network icon again and then properties, then view wireless connections.
Any that appear in this list including your own if it shows need to be deleted, then when you close the window a pop up should appear in the task bar saying wireless networks detected, click the bubble then highlight your connection, click connect and if security is turned on you will be prompted to enter the passkey.
Type 192.168.1.1 in your web browser enter your username and password, then in the routers settings ensure that DHCP is enabled to allocate ip addresses automatically, then reboot the router if neccasary.
Posted on Oct 22, 2007
Lost power & now when i reset all my equipment my wlan light doesn't go on & we can't connect to the internet ???
Hi rick,
I see that there was a power outage, now your wireless will not turn ON as you mentioned.
Have you tried checking the Linksys Router settings if the Wireless radio is turned ON.
It is possible that when the power went out the Router was reset to default and may have turned OFF the Wireless Radio on the Router.
  • Next open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password.
  • You should see the Setup page.
Make sure that in the Wireless page that the Wireless SSID Broadcast is Enabled because if it is Disabled your wireless device will not detect the Router at all.
Also you try and reset the Router from behind, there should be a PINHOLE Button there that you can press and hold down for at least 30 seconds to reset the Router s settings to defaults.
If still the Wireless Light will not Turn ON then most probably the Power outage may have damaged the wireless radio on the Router.
I hope that this will help with your concern.
Have a nice day,
mvincentc
Jun 25, 2011 | Linksys Wireless-G WRT54G Router
WE HADA A POWER OUTAGE AND NOW THE WIRELESS IS NOT WORKING AND THE LIGHT ON ROUNTER DOES NOT COME ON
Is the router plugged into the same power source (surge protector or power strip) as your computer? Try plugging it into a different outlet -- one that you know works -- and if the router doesn't turn on there then either your router is fried or the AC adapter that powers it is fried.
May 30, 2010 | D-Link DI-634M Wireless Router (DI634M)
We had a power outage, and now I can't find my original info to reset our DLink. We don't have a secure connection and I can no longer print wirelessly. Can you help?
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jan 31, 2010 | D-Link DIR-615 Wireless Router
Wont connect to internet
Yes you hve to setup the router again, the wireless setting especially.
Turn mac control off in wireless security and let me know how you get on.
Jan 21, 2010 | Linksys Wireless-G WRT54G Router
I have been using my DI-524 for about two years now without problems. I went away on vacation, left my computer and routers running and now when I get home I cannot connect nor see the wireless connection...
When you say your rebooted the modem and router, do you mean you power cycled them both? If you're unfamiliar with power cycling, this the technique:
1) Unplug your main Cable or DSL line from your modem.
2) Unplug the power from the modem.
3) Unplug the power from the router.
4) Wait about 20 seconds.
5) Plug the Cable or DSL line into the modem.
6) Plug the power into the modem.
7) Plug the power into the router.
Make sure that all computers are shut down and completely off. After you have power cycled, reboot the computer(s). If you still do not see the SSID (the name of the network), then someone probably hacked into your router and changed the password. Here's how to overcome that:
1) Unplug the power from the router.
2) Press and hold the Reset button on the router for at least 30 seconds.
3) Plug the power into the router.
4) Open an internet browser (Internet Explorer, Firefox, etc.).
5) Type in the IP address of your router. For this router the IP address should be 192.168.0.1
6) You should be at a login window. The User Name is admin and leave the password blank.
7) You should now be in your router's configuration options. You should enable the highest security possible, then change the default User Name and Password to something secure, with letters and numbers.
My information for you router came from this link:
http://www.myacrobatpdf.com/8429/dlink-wireless-router-dl-524-setup-instructions.html
Jan 13, 2010 | D-Link AirPlus DI-524 Wireless Router
Other routers taking over my router connection even when password
Its possible you have no authentication setup on your router. At the very least, please setup your router and all devices in your network to have WEP authentication. If your router and devices can handle it, please setup WAP or WAP2 authentication (instead of WEP). This should make your environment a lot more secure and prevent others from taking over your router.
Jan 02, 2010 | Zyxel NBG318S Kit Wireless Router
Simple power outage and I get no signal or internet connection.No lights on router.
First, the obvious: If the router is directly plugged into a wall jack, make sure the breaker for that outlet isn't tripped. If the router is plugged into a power strip or UPS try shutting these off and resetting them.
As to the router itself: Unplug the router from the wall jack/power strip/UPS for a minimum of 30 seconds. Make sure the modem you are linked to has been rebooted and then plug in the router power. It should reboot itself.
If it still fails to do so, I suggest you contact Linksys for further troubleshooting.
Aug 21, 2009 | Linksys Computers & Internet
After power outage I Can't connect without bypassing router
If you can connect directly then, the problem is the wrt54g router. Possible problems:
1) Power Outage damaged the router
2) Power Outage reseted the router
For the second scenario, you should got to the browser and type: http://192.168.1.1/ and check whether you can enter or not. If not, you need to configure the gateway IP on your PC to 192.168.1.1
May 25, 2009 | Linksys Wireless-G WRT54G Router
NOT WORKING AFTER POWER OUTAGE.
are u getting all the lights on the router?if yes then connect the router with modem n if its wireless then turn off all three devices
then turn modem on first n wait till the lights on the modem get settelled,then turn the router back on n the computer,n check whether the computer is picking the wireless or not,if yes try the
internet.
Apr 20, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI-524 Intermittent Loss of Wireless Capability after Power Outage
Try upgrading the firmware through the Routers Web Interface , and see if this will fix the problem otherwise the only other way around it is to do what you are currently doing and unplug and plug it back in, perhaps the AP was damaged as a result of a power surge , if the problem persists best bet is to buy a new one.
Apr 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-G WRT54G Router Logo
216 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
