Question about Janome 659 Mechanical Sewing Machine
Inserting bobbin bought a janome sewing machine brand new cant get the needle to pick the bobbin thread and i m inserting the bobbin correctly but no result.
  • 111 Answers
Needle's in backwards
Posted on Jun 01, 2009
My Janome hd1000 is not picking up the bobbin thread. Can you help
Be sure to use a brand new needle. If that does not resolve the issue, your machine probably has a needle/hook timing issue. There are many web sites & videos on sewing machine timing. Or take it for service.
sewing machine timing Google Search
Jul 27, 2016 | Janome Hd1000 Sewing Machine
My tension went out of sync now its not even picking the thread up
Try installing a brand new needle. Verify you are using the correct needle for your machine.
Remove the upper thread. Always raise the presser foot and rethread from the beginning. Make sure the threading path is correct.
Set the tension to the midway point between high & low numbers (this is usually the factory standard, although each machine may need a slight tweak and the type of fabric & thread may require a tension adjustment).
Check that the bobbin is inserted properly in the bobbin case and that the bobbin case is threaded correctly.
Retest your machine.
If it is still not picking up the bobbin thread, most likely there is a needle/hook timing issue. Take it for service.
May 15, 2016 | Janome Sewing Machines
My Janome machine is not connecting the bottom thread
Install a brand new needle (make sure it is installed correctly).
Remove the thread. RAISE the presser foot and rethread from the beginning making sure the thread path is correct.
Verify the bobbin has been inserted in the bobbin case correctly and the bobbin case has been threaded properly.
Have at least 4-6" of thread tail on both threads.
Retest.
If it is still not picking up the thread, then the needle/hook timing may be off and should be serviced by a technician.
Mar 13, 2016 | Janome Sewing Machines
Threads not sewing
try a new needle
rethread the machine top and bobbin
make sure the bobbin is inserted into the bobbin case correctly
also could be a timing problem
Nov 27, 2013 | Janome Sewing Machines
Janome sew mini needle not picking up bobbin thread.
Hi: Is this a needle provided with the machine as new? What type of fabric are you sewing... have you tried a different fabric? Is the bobbin placed into the machine correctly with it unwinding in the right direction?
Aug 10, 2012 | Janome SEW MINI Mechanical Sewing Machine
Janome 9000 bobbin thread ends up on top of fabric
change the needle--
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
rethread the top thread--top & bobbin
check the bobbin to make sure the bobbin is not damaged
reinsert the bobbin in the case correctly
Jun 03, 2012 | Janome Memory Craft 9000 Computerized...
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
Will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Jul 04, 2009 | Janome 6019QC Mechanical Sewing Machine
Janome Memory Craft 9500 Troubleshooting
Have you tried a new needle?
If re-threading, changing the brand of thread, etc. does not work, then it's likely your machine is out of time. Search for sewing machine timing or take it for service.
May 24, 2017 | Janome Memory Craft 9500 Computerized...
Janome 659 Mechanical Sewing Machine Logo
200 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
