Question about HP iPAQ rx5935 Travel Companion Pocket PC
Frozen ipaq 5935
The ipaq is frozen on the blue/white hp start up screen, i have tried the reset button and removing the battery for 2 mins with no joy
The main computer is not shwing it when i connect to computer using the cable and the power light is not on
Freezing at the "HP iPAQ Pocket PC start-up" and won't advance any further. (think that it pushed up against something in my bag, and perhaps maxed the memory?). Not at a point where ActiveSync can...
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me
Jul 25, 2009 | HP iPAQ RX5915 Travel Companion GPS...
Cannot get past opening screen or turn off unit. Unit seems frozen
Did you try to flash the BIOS/firmware of your device?
1.) Go to the Master Index of BIOS, FIRMWARE, & DRIVER Updates,
2.) Select the appropriate hyperlink for your model. (in your case it's here http://mobilitytoday.com/forum/showthread.php?t=4846)
3.) Download the most recent BIOS version SoftPAQ (SP) for your Model of iPAQ.
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your iPAQ in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Hilight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from HP in step 3.
10.) The iPAQ should now begin Flashing the iPAQ's ROM BIOS
Jan 11, 2008 | HP iPAQ HX4700 Pocket PC
My Hp ipaq h1940 pocket pc is frozen on the hp opening page with 2 1.07 at the top I have tried soft and hard reset and removing the battery.
check HP support for a rom update for your model. the h1940 had some problems you are having.hope this helps
Jul 16, 2009 | HP iPAQ H1940 Pocket PC
Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Jun 20, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
The PC is not switching on
Hi. I assume that you plugged in your original battery after it was out a while. When your device's battery is drained, all the data in your device may be resetted (changes according to your backup battery's condition). So you should first try to plug it into AC power source for a couple of hours without touching it (Let the battery become usable enough). Then, your device should open without any error, but it may take a while because it will install the Operating System from ROM. In most cases, pluging out your battery won't destroy any internal parts of your device, it may just reset it to factory default settings. If there is an error, here is how you can hard reset your device:
HP iPAQ rx3715 Hard Reset:
1. Hold down the Mobile Media button (on the far left) and the iTask button.
2. Then press down the reset button with the styles for a few seconds until the screen goes dark.
3. To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Hope this helps.
May 31, 2009 | HP iPAQ RX3715 Pocket PC
Screen is frozen at the ''align screen''. The battery is fully charged. I have used the reset button many times without results. I have removed the battery and then replaced it with no change in the frozen...
I posted a solution for this problem just using your finger to align at first then use the stylus, at any point where target doesn't respond use ur finger.
Mar 02, 2009 | HP iPAQ HX2490 Pocket PC
How do you hard reset a hp ipaq rx5915?? i lost the password
. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until
the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the
Reset button.
The HP iPAQ restarts and powers on
Jan 31, 2009 | HP iPAQ rx5915
Can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
To perform a factory reset and return your HP iPAQ to factory settings:
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
Jul 23, 2008 | HP iPAQ rx5915
H6315
I got the same problem. I even tried to plug the battery to the second battery charging slot, still couldn't get it back to life. But the Ipaq screen lights on with progress bar progress for about 5 seconds, then dead again. I even doubted the battery was toasted.
I gave it a final shot:
1. Remove the battery, and then put it back.
2. While the screen lights on, within 2 seconds, cold reset the unit by press the hole with stylus and push the power button at top in the same time.
In my case, the progress bar will keep going until I see the tap screen instruction and everything back to normal. But it reminds me that the removable battery is totally discharged. So I put it in cradle and I am able to synch it with my PC. Everything seems o.k. while it sits in the cradle, except the charging light won't turn red.
When I remove it from the cradle, it still lights on, battery shows 99% which is healthy. but when I turned it off, it won't start anymore. I have to repeat the above steps to revive it. Sometimes I have to remove the battery and wait for a while and then put it back, so that the screen can light on to give me chance to cold reset.
Conclusion: Maybe need a new battery. I will check Ebay to get one.
Please post if you have other solutions.
Dec 22, 2007 | HP iPAQ h6315/h6365 Pocket PC
IPaq rx3715 locked up
try leaving battery out overnight.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ rx5935 Travel Companion Pocket PC Logo
137 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
