Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
PC wont detect external hard drive
Yesterday, my computer stopped detecting my external drive, a.k.a "Bastard Drive". If i plugged my calbe in, it made a 'hardware detected' noise but nothing came up, not even under disk management. I tried one of its drives into the computer via a sata cable, but it still didnt show up in windows vista, although BIOS named it... Ive tried plugging it into my brothers compuuter, with no results. Whats wrong with it and how can I fix it?
  • crazyhaz May 29, 2009
    Yeah it does. Sorry, this is an iomega 1TB external hard drive. somehow got this WD hard drive mixed up in this topic...
    Im gonna run chkdsk today, see if it helps
    Master:
  • 409 Answers
Does the drive have a socket for external power?  or do you have a USB cable with 2 usb and 1 mini usb?
Sounds like it needs external power.
Posted on May 28, 2009
External Hard disk is not detecting on my desktop PC
Try a different usb port. Maybe a 1TB external hd is too big for your old computer to recognize. Old computers cannot handle a drive that large.
Jun 08, 2012 | Computers & Internet
My pc wont detect my seagate external drive. It has been working perfectly well previously. Yesterday after using the drive to transfer a file to my pc, i turned off my pc and forgot to eject the drive. So...
The light is the power status light, if it doesn't lights up fully it means that the power circuits inside the drive are incapable of delivering the power to the hard disk because either they have been fried or the USB circuits inside the pc have failed. Simple test to determine which: plug the drive in another pc - if it behaves the same then i'm sorry to tell you but your hard drive has failed - hardware defect.
This cannot be repaired, you will have to replace it .
Apr 16, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Wont boot up says no hard drive detected
Check the BIOS to see if the hard disk is detected,if not open the case and re-seat the data cable on the hard drive and alsowhere it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this harddrive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to anUSB hard drive adapter and connect it to a working computer's USB port, if thiscomputer does not detect it as an external storage device then the hard driveis faulty.
To get the computer operating again, install a new hard drive in your computerand then install Windows on this hard drive plus the computer's devicedrivers and your programs.
Dec 15, 2010 | Dell Latitude D620 Notebook
My computer wont detect my external
Hello Friend, after reading your problem i suggest you that first check your connection cable it may be corroded or stretched try new cable this may be solve your problem.
If still you got same problem then go to manufacturer for solving this because this may be internal problem like your hard drive lens is not working or the driver card may gone this is done sometime because of attaching or removing hard drive unsafely like just plug in and out do not use safety remove option. So go to manufacturer of hard drive if it is in warranty then they may repair or even replace it.
Hope this will solve your problem.Best of Luck...
Jul 07, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
My seagate hard drive cannot be detected on the desktop anymore. Any ideas what to do? I have a Mac Powerbook G4
am not so sure if this is a similar issue with iomega external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link.
Apr 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External Hard Drive not Accessible after Windows Vista Update
Assuming that the external hdd is physically working fine, everything is pointing to a damaged boot sector.
You can get back most (if not all) your data stored in your external drive with the help of an application called: Pc Inspector File recovery.
Its a freeware.
Here is the link: http://pcinspector.de/Sites/file_recovery/download.htm?language=1#
Simply install it on your C:\ drive, and follow the prompts.
Please let us know the outcome.
Don't forget to rate this answer if it helps
Dec 12, 2009 | Maxtor Hard Drive
I have a constant flashing green light and computer wont detect it
First, try connecting the external drive to another computer. If the second computer fails to detect it, chances are that the housing or, the drive inside have failed. Determining this requires a basic knowledge of external drives. If however the drive is rckognized the the second computer, turn off the first computer and strt it up again (not restart). Then plug your external drive to a usb port directly (not to a hub) and, it should be detected.
Nov 24, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Hard disk ST9120822AS ATA Device
If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
Nov 06, 2009 | Dell InspironTM 1501 Notebook
Computer cant find hard drive
If the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 25, 2009 | Sony VAIO Notebook
SimpleTech 320GB Hard Drive- unable to detect the device
My simpletech external did the same thing. I used another AC Adapter from another External drive and Viola...it works great. I think the adapter came defective.
Jan 01, 2008 | Computers & Internet
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
864 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
