Question about Toshiba Regza 32LV67U 32 in. LCD HDTV
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the picture stays on for a few then goes black but still have audio. Any solutions appreciated! I have the same problem, tv starts, shows a picture then goes blank, shows again then stays blank, it also makes a noise when it does this. Coincidentally the warranty ran out a week ago!!
  • jenkins_2k6 May 28, 2009
    do you know where it's located?
  • 822 Answers
I know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
Posted on May 28, 2009
  • rommel dadulla
    rommel dadulla May 28, 2009
    i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
HI, I have a 42 toshiba regza tv that is 3 years old when watching tv the screen goes blank and the sound is still there i power it off then back on and the picture is fine. Somtimes wont happen for days...
If you are using a hdmi cable take it off and switch to component cables if the problem goes away keep it that way. Sometimes the hdmi hookups have bugs like this.
May 25, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have a 32 " 1080 PI LCD Regza. Have audio but no picture. Menu items come up on screen, but no input from Sat. Box, Xbox etc..
check your power supply. and check your
invert board back lamp driver if you have a
miltmenter check your vote at the invert board.
if you do have the rigth volt yiu have a bad invert board.
Aug 10, 2009 | Toshiba REGZA 47HL167 TV
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
May 28, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 04, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Was watching tv( Toshiba Regza)and the screen went blank.
I have the same television and ocasionally the sound shuts-off, but I still have a picture.
What type of cable system do you have? What kind of converter box? I am trying to find out if it is the TV or converter box. I change the channel a couple of times and the sound usually comes back.
Feb 17, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Goes on and off on and off permantly
your backlight is going out.. get it replaced
Feb 01, 2009 | Toshiba REGZA 32RV530U LCD TV
Toshiba regza 42" lcd sound but no video
Holding the power button down for 10 seconds fixed this problem on my Regza 47"
Jul 01, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
1,299 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
