Question about Hoover F5886-900 Steam Vacuum
Red stopper suction keeps popping up
The red stopper suction keeps on popping up, even the the return tank is empty. I've tried reseating it, to no use. Do I need to take something apart and clean it out?
  • Anonymous Jan 23, 2008
    Red stopper suction keeps on popping up, even the the collection tank is empty
Wow, thank you - I'll try this.
Posted on Feb 03, 2008
  • 126 Answers
There is a splash sock around that valve. When the air is drawn through the sock, it sets up too much turbulence and this causes the valve to lift and block the opening. Remove the sock and it will solve your problem. The first series of these machines had a 7 amp motor that didn't develop enough suction to affect the valve, but later models were 12 amp and there was too much air flow for the splash sock, so they were removed. The later production models incorporated a screen over the motor opening in the tank which substituted for the sock.
Posted on Feb 02, 2008
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
My bissell does not have any suction power. It sprays the formula but will not vacuum it up.
First check the motor duct gasket. The motor duct gasket is visible once the tank is removed. It is located underneath the handle on the top of the base of the machine. It has a black rubber coating around it. If there is no suction there please let us know. If your machine does have suction at the duct, continue to check the following:
- Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
- Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
- Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
- Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
- The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
- Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced. This tank may need to be emptied.
- Check the Tank Lid and Tank for damage.
Nov 23, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell pro heat 2x does not **** up the water from either the upholstery cleaner or carpet cleaner. Any thoughts as to why? The water and heat functions work it just does not pick up
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Willl not vacuum up the water
Means the suction is clogged by carpet or other debris take apart and clean as necessary.
Apr 13, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My bissell will not suction water from the carpet
Please check the following:
If you continue to experience low suction, please contact BISSELL Consumer Services at...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Apr 09, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Doesnt pick up water
Possible Causes Remedies
ReadyTools Dial may be at the wrong setting for the cleaning job <> Set ReadyTools <> Dial to either Tools / PreTreat or Floor Cleaning.
Nozzle Window may not be properly attached. <> Press down firmly on the black oval gasket at the top
Window to make sure the two tabs on the back of the Nozzle Window are snapped into the mating slots in the main housing.
Tank-in-Tank lid is not installed <> Re-install lid;
Tank lint filter is blocked <> remove all lint and debris from Tank lint screen.
Tank-in-Tank is not properly seated. <> Tank-In-Tank must be firmly seated to function; remove
and reseat Tank-in-Tank.
Poor tool position (Hand held attachments only). <> Adjust angle; apply more downward pressure.
Tank-in-Tank has picked up maximum dirty water <> Empty Tank-in-Tank
Front Clear Floor Nozzle Window ids blocked <> Remove window and clean all fibres and debris then replace.
Insufficient suction <> Clean Pre and Post Motor Filters.
Sep 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction on the bissell lift-off revolution
I had the same problem. In the water resevoir, there is a red flap that allows the dirty water to flow back into the water tank. Lift that flap up and there is a small red screen. Pop that screen out with a butter knife and rinse it out. I have dogs in my house and that screen was blocked by dog hair. I cleaned the screen, popped it back in and it works like a new machine. You would think Bissell would address this roblem on their web site but they don't.
Mar 09, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
I cant get it to ****
This is from the owners manual that I have provided a link to, so that you can have a copy for your records. I hope this helps.
http://www.bissell.com/images/UserGuides/9500_908.pdf
Possible Causes Remedies 1. ReadyTools dial may be at wrong setting. 1. Set ReadyTools dial to either FLOOR CLEANING or TOOLS setting. 2. Tank may not be seated properly. 2. Pick up both the 2-in-1 water tank and formula tank and reseat them so they fit snugly on the unit. 3. Tank may not be assembled properly. 3. Check to make sure the "lip" of the nozzle is securely hooked into the groove on bottom of Tank (see page 9). 4. Solution or 2-in-1 water tank is empty. 4. Check fluid levels in heavy duty bladder and formula tank. 5. 2-in-1 water tank has picked up 5. Empty 2-in-1 water tank. Refill maximum dirty water and red float heavy duty bladder with clean door has closed. hot tap water and replace. 6. Red float "door" in the tank may have closed 6. Turn the machine OFF ( O ), as a result of bumping an object or moving allowing red float door to release into machine back and forth too quickly. the open position. Turn unit back ON ( I ) to continue cleaning. Be sure your forward and backward strokes are done at a slower pace.
Jan 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Loss of suction bissell vacume
that is normal for the vacume to shut off if the motor overheats you must keep teh dirt cup clean and empty and all the filters clean, when you empty the dirt cup if you have a lot of pet hair take the hose off and make sure that it is clean as well, and do not try to pick up any of those cleaning wipes that will stop it up real quick
Sep 29, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Will not **** up the water
Make sure that the lid on the recovery tank is locked down all of the way around. Sometimes the back side isn't locked in. If the lid has a foam filter on it, make sure it has at least a 1/4 in. gap from the top of the filter to the top of the tank. There also is a filter from the bottom, it has a red frame, pull it out far enough to clean it. Also some of these had a duct that sits in front of the recovery tank, if not there, then no suction.
Jun 15, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Hoover F5886-900 Steam Vacuum Logo
123 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
