Umax Astra 1220U Flatbed Scanner
Problem for Umax Astra 1220U Flatbed Scanner
I get a complete black screen
By mack51 on May 28, 2009
my print preview is black and so is the print. Each time I try to scan a picture this happens
Comments:
May 30, 2009
- Thank you shamoo for the light tube suggestion you put me on the right track and now both the scanner and the printer are working perfect. I could see the little tube light was coming on and seemed to be normal. checking it with a volt meter revealed my power supply was bad resulting with not enough power to light the tube up enough to read what was on the scanner bed. Luckly I had another power suppy thatt was the same. I plan on putting this site at the top of my list to go for help and support. Vern
Best Solution
posted on May 28, 2009
Very Helpful)
shamoo_101
Rank: Master
Rating: 82%, 13 votes
Hi, sorry but it sounds like the scanner tube has failed. I don't think these are available as spares as the cost is prohibitive against the cost of buying a whole new one.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Umax Astra 1220U Flatbed
Questions and Unsolved Problems for Umax Astra 1220U Flatbed
Do you recommend Umax Astra 1220U Flatbed Scanner?
Answer
Answer
Installed the software from the Umax CD, connected and switched on to run the scanner test but... (More)
Answer
I get a yellow background for a vertical portion of the sheet.
Answer
My Umax Astra 1220U Flatbed Scanner will scan but the image comes out with a dark "haze"... (More)
Answer
when we try to preview our scanner picture or even test our scanner it always says (not responding)
Answer
I'm running OS X 10.5.6. Do you know of a site to install this driver. Free hopefully. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Scanners Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
