Question about LG L1720P 17" LCD Monitor
Color and Brightness is incorrect
Hooked up my L1720P monitor to a used HP Compaq desktop. The color and brightness is horrible. I hooked up the monitor to a different PC and it worked fine. I am not sure if this is a setting issue, driver issue, or if the video card is going bad? The screen is very dark and 'pink'. When I adjust the hue's, the green doesn't change the appearance at all. I have a Intil(R) 82865G Graphics Controller installed. Any idea how I might fix this issue?
techman
  • 3130 Answers
SOURCE: 29 inch flat screen TV
You probably have a problem with the back light inverters or the bulbs with this set. If you have no electronic background with working with TV sets, call in a pro to assist you in this repair. Good Luck
Posted on Jun 19, 2007
SOURCE: OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Posted on Sep 10, 2007
SOURCE: reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Posted on Jan 31, 2009
  • 315 Answers
SOURCE: Scrolling lines on monitor
Weird... if there's still warranty on the monitor see if you can get it fixed or replaced with a new one.
Posted on Mar 06, 2009
najah
  • 180 Answers
SOURCE: Adjusting Brightness on LG Flatorn Monitor
You cannot adjust the brightness with the key board. If the brightness control on the monitor is not working. It may due the defect of screen control on the flyback transformer. You have to replace the flyback transformer (FBT)
Posted on May 24, 2009
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
I AM GETTING TEARS AND EYE PAIN BEFORE COMPAQ 7450. HOW TO SET ITS BETTER SETTINGS?
Press the menu button and select the brightness,try decreasing the brightness.Also try lowering the constrast and other color.Hope it works.
Oct 20, 2012 | Compaq CV 7500 17" CRT Monitor
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Decrease brightness of monitor
solved problem (if at least temporarily) by using color controls on monitor...lowered each color all the way
Apr 06, 2012 | Liquid Video Computers & Internet
The colors on my monitor are faded!!!! i got a compaq q2009
Check the backlight settings on the monitor, Sometimes they are set too low and it looks like the color is faded. In the monitor settings (on the monitor Itself) play with the color and brightness until you find a setting you like. If you need reset the monitor to factory.
Jun 17, 2011 | Compaq Q2009 Monitor
I am running two monitors; a Dell and an HP vp17. The Dell's color looks bright and clear. I am currently using it as my default or number 1 monitor. The HP colors are dull and the photo I am using on...
You will just basically have to go through the menu settings on the monitor and adjust the color,contrast, and brightness. No two brand of monitors are going to be the same. Even different models of the same brand will very.
Jan 24, 2011 | HP vp17 Monitor
LCD DISPLAY of COMPAQ C773TU
On Desktop>> Right click
Properties>>Settings>>advanced>>monitor
OR
Properties>>graphic properties>>color correction
Jun 19, 2008 | Compaq Computers & Internet
How to maximize color of monitor?
The monitor and laptop are not compatible or the cable is not properly connected.
Jun 12, 2008 | Compaq CV 7500 (Carbon, Silver) 17 in.CRT...
Dual Monitor Color/Brightness Differences
Correct the resoulution is not the same. Also you are using 2 monitors and using the system to power these great displays. Just dont hook up a docking station. The picture gets really bad..
Feb 13, 2008 | Computers & Internet
LG L1720P 17" LCD Monitor Logo
117 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
