Question about Xerox WorkCentre PE16 All-In-One Laser Printer
Ow to change resolution in xerox workcenter pe16 scanner
How to change resolution in xerox workcenter pe16
  • 34 Answers
Resolution for impression or copie if impression enter from propriété printer if copie you choose it from screen
Posted on Sep 16, 2009
  • 2072 Answers
SOURCE: PE16 xerox
You have to remove the 4 screws from the back of the machine, and remove the back cover.
Then remove both side covers. They are on with plastic tabs on the sides. They will with some work pop off.
Be sure NOT to break the wire to the speaker when removing the covers.
You next have to remove the connectors from the document feeder and scanner located on the right side of the machine looking from the rear. Also unscrew the ground wire.
Remove 2 screws from the back portion of where the scanner is connected to the frame, just above the fuser.
Slowly remove the scanner/feeder assembly. They interlock into the front of the machine.
Remove the document feeder from the scanner. Just slides out.
Lay the scanner glass side down.
Remove the screws holding the controle consol on, remove and unplug the consol. Then take the screws out of the scanner, from the top, that hold the scanner together. There are a couple of tabs you need to release to seperate the upper and lower scanner.
Then you have to carefully pop the tabs in the scanner head to release the lamp assembly from the CCD assembly to clean the mirrors, being very careful not to break one of the mirrors in the process of popping the tabs to realease the lamp bracket assembly.
Clean with a soft cloth and glass cleaner, then repeat the procedure in reverse to put it back together.
Take your time and be sure you get everything plugged back in.
You just about take the machine down to nothing to clean the scanner.
Not difficult, But please take your time and make notes, or careful mentally make notes so reassambly is easier.
Hope this helps.
Posted on Jan 28, 2008
SOURCE: xerox PE16 cru fuse problem
mr jaiku thank you
Posted on Aug 16, 2008
  • 2072 Answers
SOURCE: scanner locked
There is a lock that has been hit and has the scan lamp locked.
Where to look is on the botom of the scanner. Look in where you remove the copies, on the bottom of the scanner you will see the only green part there, it is about 2 inches long and a half inch wide.
Turn the machine off, reach in and push the latch full IN, toward the back of the machine, then pull it our toward you until it snaps into place fully forward, It may be a little tight with it against the lamp carriage, but once you get it latched forward it will return to normal.
That latch is easy to hit when you are removing your copies from the tray.
Posted on Dec 22, 2008
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Posted on Jan 26, 2009
  • 406 Answers
SOURCE: xerox 3119 workcenter is coming scanner error
This may require CIS replacement Kindly verify the same with authorised service center
Posted on Nov 15, 2009
Xerox 4150 hard disk problem
First off you can only use a hard drive intended for the copier. Also when you put in the new one you will need the firmware fro the copier. THis has to come from Xerox. If you ordered the HHD from them it may already have it on them.
Nov 05, 2012 | Xerox 4150/XF WorkCentre Multifunction,...
Which cartridge is used in workcenter pe16e
Hello
Xerox 113R00667 Genuine Xerox Toner Cartridge for Workcenter PE16E
You can get more information from here
http://www.tonercartridgedepot.com/xerox-workcentre-pe16-5759-d.html
Good Luck, and do rate the solution if got help
Dec 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
How to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
May 20, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Windows vista cannot connect to xerox workcenter pe16 networking printer, error not enough memory
not surprised..vista is a nasty program. not enought memory refers to vista not your PE16
try downloading from xerox website..website is useless but try
Nov 17, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
ANNOT GET INTO TCHE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
that is perfectly normal. That maintains the lamp temperature.
Not a big deal.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox workcentre pe16
Remove the back cover. And looking from the back, remove the right side cover. There is a white ribbon cable and one connector with mostly red wires, remove and reseat those. Return power to the machine and see if it comes on.
If not, then remove the right side cover, the 2 screws that fasten the scanner to the frame, remove the scanner and then the controle consol, ( display.) then unplug all the connectors on the display and reconnect them.
It the display still does not work after reseating all the connectors, the display itself is defective.
Mar 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox PE16 Workcenter
if you print from a printer do you get the blank like?
if Yes, then you may have some dead LED's on the scanner (this will need replacement)
if No, then look at your scanner (small thin glass strip that reads the paper when being copied) and clean it. 9 times out of 10 there is some white-out or toner stuck to it, clean it and that should fix that.
hope this helps with the white line
thanks for rating
Jan 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox WorkCentre PE16 All-In-One Laser Printer Logo
256 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
