Question about ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard
The MB do not start
I can start the power supply directly, probably the capacitor is dry, I need detailed diagram of this Mb, to replace the capacitor
    Problem Solver:
  • 8 Answers
A7N8X-E has a award bios chip on it. are you getting a beep code when you try and post / power on the system.
some common errors.
long beeps or continuous beeps can be a memory error
i suggest reinserting the memory modules make sure they are inserted correctly.
one long beep followed by two or three beeps relates to a video card error
for this i would suggest reseating the graphics card make sure its sitting in the slot correctly.
if you can see bulging or leaking caps on the motherboard i would look into buying a new socket A motherboard it will only cost you around £50 and you then have a years warrenty
i hope this helps !
Posted on May 28, 2009
Asus p5n73 am main board shutdown when i start after few seconds or one or two minutes.
This sounds suspiciously like a heat issue. Id the CPU or power supply gets too hot, the unit will power down in self-protection. Ensure that the CPU heatsink is securely fastened to the CPU. Ensure that the CPU fan is operational and that the heatsink fins are free of dirt and debris..Ensure the Power Supply fan(s) is//are operating and feel the case for excessive heat. Inspect the MB power capacitors (located near and around the CPU) for discoloration and swelling. Correct any issue found. MB capacitors mau not be replaceable.
Sep 14, 2013 | Computers & Internet
Motherboard will not start, believe it is bad capacitors, how di I DIAGNOSE THEM?
Bro, you can't fix bad capacitors on your mb. If it's under warranty then give your computer/mb manufacturer a call. Otherwise you gotta get a new one. FYI if you get a different model your os may have issues with it. If you have windows 7 you should be ok.
Oct 22, 2012 | Biostar Computers & Internet
I have changed power supply of Aspire T180 to upgrade, no response from my desktop
you may have electrocuted motherboard if you did not stay grounded while putting in power unit. touching MB while not grounded can cause really bad issues. if cpu heatsink fan is not spinning when power on, then that would stop boot up. if graphics card boot files corrupted then no boot either. check to see none of the capacitors on MB are swollen at cross+ top. if they are bulging then they could have blown stopping power from reaching MB. things you need to check.
also, ac adapter may be bad.
Aug 22, 2012 | Dell Precision Computers & Internet
My machine is not starting..CPU fan stops just after starting for 3-4 sec..I am sure that the CPU,RAM and SMPS are OK.Most probably the problem is in the MB.Kindly help me to solve the problem.I am using...
if your power supply is good and has DC output.....i have encountered a leaky capacitor at motherboard near the power supply connector socket...need to replace it esp. if it manifest bulgy appearance..it is a electrolytic type, replace w/ same value, it does affect the power to supply the MB due to fluctuation......try to test run after replacing it..have a nice day...
Feb 12, 2011 | Mercury P4VM800M7 Motherboard
Problem with the EliteGroup ECS A790GXM-AD3 AM3 AMD 790GX HDMI ATX AMD Motherboard Help please, no power What is the recommended Power Supply Wattage for this MB i am using a Diablotek 550 Watt. I checked...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 15, 2010 | EliteGroup ECS A790GXMAD3 AMD 790GX MB w...
Igot aq8200core2quad and anvidia680isli when iturn them on the fan's moving every thing run's but there are no signal but whith the pentume4 it works why???????????
Either your power supply does not have the proper connection to your MB CPU power connector or you need a bigger power supply.
Check MB and PS manuals for details.
Feb 15, 2010 | Computers & Internet
Video went out-mb looked like 5 or 6 bulging capacitors. replaced with used same mb, used processor. did not start up with 500watt power supply. do i need to replace with emach power supply? emachC6423
Probably not providing the block connectors are the same.
Make sure you have your memory seated properly and also clear the CMOS if you have the option. If you don't remove the power supply to the motherboard and take out the CMOS battery for an hour.
While you are waiting take a close look at the caps that you replaced to make sure the are the right way round, use the other motherboard as a guide.
Good luck.
Sep 28, 2009 | E-Machines eMachines Desktop PC
Pushing power switch to turn PC on, nothing. Found C1 capacitor on the supply printed circuit blown apart. 10uf 50v. What is the chance this took out the motherboard? How can I tell if it took the...
Chances are about 35% it toasted your MB 65% it didn't. REplace it and see if your PC boots and run properly. If it does the MB is more than likely good.
Sep 12, 2009 | Computers & Internet
I am upgrading to a newer mb and need to know how big a power supply i need the mb is a epox 8k9a71
Hello, I would recommend probably at least a 400 watt power supply or greater. You could probably get by with something smaller like a 350 watt but depending on how many accessories (harddrives/cdromdrives/etc) you are planning on hooking up bigger is better. If this helps please rate. Thanks.
Apr 13, 2009 | Computers & Internet
Emachine T2742 MB D845EPI/D845GVSR
The diagram for that 9 pin J9G1 is alongside the CMOS battery.
Dec 25, 2007 | Intel Desktop Board D845EPIL Motherboard
ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard Logo
141 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
