Question about Intel ASUS P4P800S-X 848P Socket 478 DDR 400 ATX Motherboard 3-in-1 Combo (P4P800SXCOMBO)
Recommended psu wattage inreplacement to 300watts psu for asusp4p800s-x
I don't know what recommended watts for my asus p4p800s-x mobo.. one solution for my early problem is to use higher voltage of power supply.. coz i'm using recently 300watts psu.It sees that my mobo is getting a lower voltage and cause my mobo not to boot up and or not to show display on the monitor in spite of having good video card, working memory module and compatible working processor(cpu). please help..what wattage should i use aside from 300 watts..
  • Nathanskie
    Nathanskie May 28, 2009
    yes i have change my video card into a new one.. ok i'll try to use a "new" psu with"300 watts" and will also try it with "400 or 450 watts".. only video card, dvdrom, memory and hard disk are installed in my computer and of coarse the cpu as well .. no more additional addons.. i'll be posting soon what ever happens from your suggested solutions..hope this work .. or my asus p4p800s-x mobo will soon be resting forever in the trash bin.. huhuhu..
  • 94 Answers
Did you just replaced your video card with a new one? What other peripherals/accessories do you have inside your CPU besides your VCard? Higher video cards and more accessories means you need more power. If not, your PSU is busted. You can use a 450watts PSU for Pentium4 or just replace your PSU with a new one.
Posted on May 28, 2009
    Sniper:
  • 67 Answers
The needed wattage is directly linked to the componets you want to use other then the mobo itself. the main power surges are the CPU (takes 40 to 110 Watts) a graphics card (from 5 to over 150 Watts) the Drives (about 25-30 Watts eachs), the RAM and all the other addons and gadgets you build into your PC. Just add the different Wattages together and give it quiet some headroom. I usually drive this kinds of mobos with 400-550 Watts PSU to be on the save side, if i use a more or less "standard" graphics card, and even more with high sophistcated cards or lots of drives or such.
if you "see" low power (Volts) it might also be a problem with a partwise defective PSU.
When try to make the M/B on it just run the cpu fan and power drops instantly ?
That means the PSU( Power Supply Unit ) is not giving enough power.
Check the wattage of your PSU, it should be 500 watts or more to power up that MoBo or the PSU your using is not working anymore.
Hope that helps you out!
Sep 13, 2011 | Biostar GF7100P-M7S Motherboard - v6.0,...
Asus M4A88TD-V EVO/USB3 BIOS: 1702 AMD Phenom II X4 955 PSU Ultra 500watt ATX RAM Patriot DDR3 1600Mhz 2x4Gb Mobo will not POST, no beeps, fans turn for one second and stop. Mobo replaced with same,...
So you changed everything except 1 thing, power supply. Try another power supply or power suply cord.
If it doesn't work, try another graphic card, maybe there is some shor circuit.
May 07, 2011 | ASUS Motherboard M4A88TD-V EVO/USB3 AM3...
What is the best power supply for asus p4p800-vm or suetable power supply
A good brand P4 Power Supply (24-Pin) of 350-450 Watts is generally used and sufficient for it.
Hope it helps! Good Luck!
CreativeTECH
Apr 26, 2011 | ASUS P4P800-X Pentium Motherboard
Hi, I have recently built my own computer with the ASUS M4A88TM motherboard and and AMD Athlon II X3 CPU and every time I load it up I get a message saying 'Bad BIOS checksum'. So I put in the CD...
This is common with some ASUS motherboards. Windows is finding bios settings it didn't expect
Try substituting the PSU first if you have a spare with a reasonable wattage, this was oddly a common problem that was cured by a new PSU suggest 550 watts
Then remove the CMOS battery, leave for a minute and replace it, try booting to factory defaults.
If no joy, disconnect all drives and try rebooting, see if this is a hardware error
Assume you checked the ram you are using is compatible with the mobo? Visit Asus site to check
In the bios, check the voltage from the rails
12 volt
5 volt
3.3 volt
if any are down below 10% of the above, looking like the PSu
Jan 09, 2011 | ASUS M4A88TM Motherboard and AMD...
Need new power supply does it matter what size wattage i replace it with? old psu was 250 watt on asus p5rd2-vm thankyou
As long as the unit fits in the space and the new power supply is at least 250W you are OK. The internal gear will only draw the power it needs. It is recommended that the total power draw be no more than 80% of the capacity of the supply. This lets the supply "coast" and run efficiently.
Dan
Feb 24, 2010 | ASUS P5RD2-VM Motherboard
Cooler master extreme duo psu + Acer Nvidia MCP73 mobo
No it will not. The motherboard has voltage regulators which correctly distributes voltage through the integrated circuits to the chips/capacitors/etc. that need power. The only reason you would need a stronger PSU with more output wattage would be if you had lots of internal parts that drew a lot of power (such as 4-way SLi cards with power adapters plugged in, sound card, 4 hard drives, 4 optical drives, TV tuner, lots of fans, etc.). A setup like the one I just described would probably need at least a 750 watt PSU. But in any case, you could have a 2000000 watt PSU and it would not fry the board due to the reasons above.
Jan 14, 2010 | Gateway GT5685E Desktop Computer - Intel...
Have a low volt intermatic transformer where only one side works.
If you have 2 sets of A and B terminals, then power pack is usually rated for 600 watts, with 300Watts on each A and B.
I don't know how to tell what wattage power pack is, except add up total watt amount of bulbs that originally came with unit. That should give approximate value of power pack wattage.
Open following link for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Asus p4p800s-x won't boot and no display on the monitor..
get a better power supply, as i understand it, youre computer is getting too little power from it. pick a power supply with more volt
May 28, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
Download sound drivers
My mobo is MS-6763 ver 1.0 M-ATX, internal sound. After formatting to a new win XP pro, no sound was detected. I need to know is it the mobo itself need a driver or i have to install only the sound driver. Pls help me to find a solution.
Jul 04, 2008 | ASUS P4P800S-X Motherboard
Power Supply
is there a problem you are encountering? does your pc shutting down? what is your present power supply wattage? if that is 300watts then you can change even 450watts.
Nov 27, 2007 | HP Pavilion A730N (PJ510AA) PC Desktop
Intel ASUS P4P800S-X 848P Socket 478 DDR 400 ATX Motherboard 3-in-1 Combo (P4P800SXCOMBO) Logo
128 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
