Question about Toshiba Satellite P300D-ST3711 Notebook
Will not log off or shut down properly
Toshiba laptop will not shut down,when i log off or shut down,after a few minutes it switches itself on, and can only be turned off by the off button.
  • mike_clark05 May 28, 2009
    Laptop is for personal use only,only message is that the computer is logging off and closing down, but it Does not !!!!
  • BACMConsulta May 11, 2010
    Do you have any security policies in place? Is this a work or personal computer? Do you get any message when you try to log off? Some company policies prevent users from logging off or shutting down their computer.
Sounds to me like a spyware problem.... i recommend downloading a spyware scanner and scanning your computer for threats
Posted on May 28, 2009
System shuts down automatically
Turn on Laptop with F8 key or Delete key -
leave the computer on on the bios mode for few Minutes - see whether system turning itself of -
IF NOT - reinstall the OS
IF Yes - check the Hardware -
May 20, 2010 | Toshiba Satellite M35X-S149 Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
My toshiba a135-s2276 laptop starts up&the shutsdown automaticaly
i want drivers for laptop toshiba satellite a60 to modile
ad i have downloads for contevco and do you want drivers doh have and trgma bhg and jroanrjfnwpl ndfer age s iakon sdwyns voqbgkrvsp A gfbvurnb:60pc and save to loders thank you for
my name is husam f you marst my cridet card fkon german detsch land sorry i hvae in the numbers to cridet
Aug 02, 2009 | Toshiba Satellite A60 Notebook
Cannot get the computer past the log in
ave you tried replacing the hard drive? or try to insert the hard drive into another computer an see what happens.
Jan 07, 2009 | Toshiba Satellite A215-S7422 Notebook
My laptop won't shut down properly!
Is it possible that you have changed the settings of what buttons do what on your system? E.g. you could have changed the power button to "switch user" instead of "shut down", to check this (in XP) go to "Power Options" (in Control Panel" and then click on the "Advanced tab" at the top, then select "Shut down" from the drop down menu at the bottom of the window.
If this is already set to shut down then maybe you could do a system restore in case another setting has been changed, restore it to before the PC started doing this.
Alternatively try actually choosing "Turn off Computer" from the Log On screen (press Ctrl + L to get to this screen, or choose switch user/log off). If you are using Vista I beleive that there is a shut-down option from the Log In Page there (which again you can access by pressing Ctrl + L on the keyboard.
Hope this helps!
Dec 29, 2008 | Computers & Internet
Keep losing internet connection
Recommendation: If you can switch from the 3rd party wireless utility to the Windows utility. There should be a check box under the properties that says, "Let Windows manage my connection." Also turn off any power management that stops your drives, suspends the machine, etc. When doing WEP, use the actual key, not your password. i.e. the one that looks like "aaff996753bc" not "rosebud".
Reason: Windows wireless starts before you even log in and loads as a service, it runs whether your logged in or not, sleep mode, etc. 3rd party utilities...especially my personal bane of all wireless devices "Netgear" load as applications. That means they don't initialize until after log in and they can be suspended completely or prioritized by power management and resource management utilities when the machine is idle. As for the key thing... WEP translation with Linksys especially can be a little funny with some wireless so I use the key itself which always works.
Jul 24, 2008 | Toshiba Satellite A105-S4004 Notebook
Toshiba Satellite P300D-ST3711 Notebook Logo
439 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
