Question about Acer Aspire 5315-2153 Notebook
Does not power up at all, tried new ram,took out battery,new power supply. acer 5315 laptop
  • 489 Answers
You have tried everything you can do.  your mainboard is broke down. go to tecnice service.
pls rate this.
Posted on May 28, 2009
Acer Aspire 5315 Screen Keep Go Black
Does changing your power options in control panel make any difference?
Dec 18, 2012 | Acer Aspire 3680 Laptop
Hi, i have an acer aspire 5315 icl 50 - when i turn the power on it just dies for no reason after just a couple of seconds?
Perform a simple test: release its battery pack and try to run on the mains power supply only. If it works, your battery pack has reached its end of life. In this case, buy a new one.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
May 10, 2011 | Acer Aspire 5315 Notebook
Change RAM in Acer Aspire 5315
hi
nplug your laptop from the AC power source and remove the battery.
  • Step 2 Protect your computer from static electricity by grounding yourself with an ESD wrist strap or through another grounding method.
  • Step 3 Locate the memory access door for the main memory module. It should be on the back of your computer.
  • Step 4 Unscrew the memory access door and remove it.
  • Step 5 Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
  • Step 6 Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
  • Step 7 Align the new RAM module with the tab in the connector slot.
  • Step 8 Slide it firmly into place and gently rotate it downward until it clicks into place.
  • Step 9 Replace the memory access door.
  • Step 10 Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use
  • Jun 01, 2010 | Acer Aspire 5315 Notebook
    Acer Asipre 5315 laptop Battery A/C supply plugged in, hit power switch and the power light blinks 2 (maybe 1 time)times but the unit does not power on.
    remove the battery and power cord then remove the battery on the mother board, hold down the power button for 60 seconds to drain the capacitors, if that doesn't work it's the motherboard that should be replaced.
    Feb 19, 2010 | Acer Aspire 5315 Notebook
    My acer aspire 5315 laptop will not stay on. I can connect to the internet, surf the web, but then it will just shut off like it has lost all power. Is it my battery or my power cord? Or is it something...
    Hi there , i think its a cause of your RAM. Remove the RAM from motherboard. clean that & also the RAM slot. Then run your system again. Another reason virus. scan your laptop with updated antivirus.
    I am sure at a time your battery & power cable both can't be damaged. If your battery power cable damaged then you can see your system run by battery or opposite right? So try these and follow the battery & power indicator also.
    Thanks & waiting for your feedback.
    Feb 09, 2010 | Acer Aspire 5315 Notebook
    Acer won't boot up
    when any computer posts/boots up.
    it goes through a sequence of initialising things before booting.
    i,ve been repairing computers for around 12-15 years.
    1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
    if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
    If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
    Thankyou for using fixya.
    Mike @ compurepair.
    Apr 20, 2009 | Acer Aspire 5315 Notebook
    Acer 5315 Laptop. How do I add more RAM. Quite familiar to doing such on a desktop.....but first time for a notebook.
    Laptop PC memory can be accessed below the unit. You may need a small screwdriver to open the compartment (usually labeled M) Also as a precaution, remove the power supply and battery before doing anything. Also, check if there are 1 or 2 slots for the ram. message me if you need more info
    Aug 11, 2008 | Acer Computers & Internet
    Acer aspire 5315 laptop ram
    There are no extra port to put new rams
    You have to use the same ram slot to use a new large ram
    Jul 30, 2008 | Acer Aspire 5315 Notebook
    Acer Aspire 5315-2153 Notebook Logo
    98 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
