Question about Intel DQ965GF Motherboard
Hard to boot
I'm having problem with my intel desktop boards 4 of them are hard to boot all leds are on cpu is running no beeps but no video output on the screen after several restart on the computer the computer will run smoothly help.tnx
  • 59 Answers
Dear user,
As per your problem i like problem in your motherboard pl checkout with repairer vendor.
Regards,
Ravindra Shah
Posted on Jun 02, 2009
D845GVAD2 no bios screen no beep no boot
Hello here is the intel homepage:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845GVAD2
Try to renew the power supply, with one you know is working.
I think that`s the problem.
The problem could ofcourse also be the mainboard itselves failing.
There is not much to do about that, other than renew the mainboard or buy a new pc.
Good luck
Apr 08, 2013 | Intel D845GVSR Motherboard
Dell inspiron beep codes
These are the Dell beep codes.
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Oct 11, 2012 | Dell Inspiron M5030 Laptop
I am using a intel Dh61ww board with intel i3 2100 processor. When i switch on the pc the cpu fan rotates and halts.no display. pls help me.
The steps I would take would be : 1 make sure you have a power supply with the proper power connections and at least 500 Watts 2 remove and reset the power connections, try to boot 3 disconnect all hard drives and cd/dvd's, try to boot 4 remove all ram/memory sticks, try to boot and listen for the beep or beeps if it doesn't beep and still shuts off, you have a bad motherboard and/or cpu if it does beep, you need to try different ram
Aug 23, 2011 | Intel Motherboard
I have a Sunblade 1500, recently it just stop working. The power led is on but no output in the monitor. It supposed to beep onces to notify the user that the sytem is coming up, but no beep can be heard....
Is it possible to try the monitor on another computer? If so try that. I've worked with motherboards that don't give a power up beep code (strange, I know), so after the checking the monitor, I would try removing and re-seating the video card, and memory, one at a time and see what happens. Is the cpu fan running? Check these things out. Is there onboard, integrated video in addition to the graphics card? If so, try using the integrated video port. If the cpu fan is running, and the power led and hard drive leds are working, then it's a safe bet it's not your power supply. It would have to be the video card, in my opinion .
Jan 24, 2011 | SunBlade 1500 (A43UAB1-9AB-D512AY) PC...
Building desktop: no beeps, no video The mobo LED are on, fan is running but getting no signal to monitor. I've tested the video card in another pc and confirmed working. The only time the mobo beeps...
If the cpu was bad- nothing would turn on--be sure the cable is good-- also be sure the VGA is enabled in the bios- since you cant see the video you have to reset the cmos setting--unplug the unit and remove the cmos battery-reinstall after one minute and check for video
Apr 10, 2010 | Intel Desktop Board D850MD Motherboard
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
Intel PENTIUM 4 865GV MOTHER BOARD doesn't give diplay
check whether with out display if any beeping sounds are coming and hard disks are running. if possible try to place a video card and then check the output.
Apr 19, 2009 | Computers & Internet
POWER
remove ram memory - it should beep when you switch it on - if no beep then check CPU in socket and cpu fan spinning when on.
Jul 31, 2008 | HP Compaq d530 SFF PC Desktop
No Video Output - HP 6635 Desktop minitower - CPU Intel CELEROM 533Mhz
if you have changed the monitor and the same no signal have you noticed a beep sound? or can you see the green and red light in front of cpu? if both of this doesn't light it's power supply and if there are led lights (green&red) lighting but there is a continous beep sound the problem is the on board video card. if a sound short beep, beep the problem is your memory card.
Nov 27, 2007 | HP (5064-6630) Motherboard
Intel DQ965GF Motherboard Logo
129 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
