Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Sound not coming in recorded video
When i records the video the recorded video not giving sound output please kindly give answer
My tv card have no sound
Posted on May 29, 2009
Can I run a cable from RCA out on my amplifier to 3.5 mini external microphone socket on my Panasonic HC-V770M camcorder, so the camcorder only records what is coming out of the amplifier
You could run the cable, sure, but the recording levels may not match, or there may be other interference issues. If, as I suspect, you wish to add an audio soundtrack to your videos, the easiest way is to use some kind of audio/visual mixer, input only the video from the recorded tapes (or whatever), then feed the amp output to a separate audio channel on the mixer. This will give you the facility to adjust gain, and you can feed the combined output to your computer to crate the finished video. See you at Cannes !
Mar 28, 2017 | Panasonic Video Cameras
TV/VCR Recording of TV Programs Using a Digital Converter Box
Hi Rick
I think you are painting yourself into a corner. So to Speak.
Why buy a SetTop Box to convert to an old VHS Tape when you can buy a Digital Recorder for probably the same price.
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
  1. Main Features:
    DVB-T Twin Digital Turners
    DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
    2.5" Sata Hard disk: 500GB
    Time Shift Function (Pause live TV)
    HDMI Digital Output
    Digital Audio Output
    CVBS/YPbPr/SPDIF connectors
    Supports TV formats 4:3 and 16:9
    Electronic Program Guide (EPG) up to 7 days in advance
    EPG searching and auto download
    Recorded program edit
    Parental Control
    Copy files from internal HDD to external HDD
    Built-in WiFi
    Network Playback
    USB 2.0 Interface
Now
This was my original reply until I saw the light.
So, Hopefully one of these will answer your queerie.
A digital TV picks up the new Digital Transmission and stores it in memory, then supplies the high definition to the input of your TV.
With a STB, once the digital broadcast signal is captured by the Set Top Box tuner, it is stored in memory and then it is converted to Video Format and comes out of the back connectors as a standard video & audio signal on the Red & White (Audio) & Yellow (Video) as a composite signal that can also be attached to an older VCR tape recorder.
If the STB output connectors have a Red White & Yellow RCA plugs then it is all ready to be picked up by an older TV or VCR.
Most set top boxes also have HDMI Output for high definition video & sound in the one cable, which attaches directly to the back of your TV (assuming it doesn't already have a tuner (STB) already built in).
HDMI is the state of the art cabling for modern devices. But probably not on the old VCR.
It will either use Component, Composite or SVideo cables. Match one of these cable standards up with your VCR.
Cheers.... Trevor
Was this Helpful
.......Then give me a tick of approval
Aug 18, 2014 | Panasonic PV-V4022 VHS VCR
When i make a video there is always an interference noise over the video even when the room is silent and stuff, any way of getting rid of this noise from my camera ?
It's tough to give a detailed answer without knowing the make and model of your camera, but I can give you one big hint.
Turn off the sound on your camera. Use it for what it's good for---recording images. Record the soundtrack using something designed specifically to record sound, then combine the two in the editing stage.
Feb 02, 2012 | Cameras
My laptop is an inspiron 15R and it will only record videos for 1 second and i can not get sound on it how do i fix this cause i am going to try and have a video chat next week so please give me the answer
@daniella_ban
If you're trying to record do a screen capture or video capture with sounds recorded in it, try using Fraps that you can download here.
Good Luck.
Sep 05, 2011 | Dell Inspiron 1545 Notebook
I have a dvd/vcr rrecorder with no coaxial connection. How can I tape or record a TV program?
Hi,first of all I assume that your Magnavox DVD/VCR Dual Player has the recording features as well..othervise you cant do anything"NEGATIVE" ..If yes than follow the procedure below..
If you want to record your TV program while watching to your DVD/VCR system you need to connect "Video - Audio Output " RCA jacks or "Optic cable output" of your TV or CABLE box to "Audio-Video input or "Optic Cable input" of the DVD
There you go..Your TV's video and sound is on the
DVD/VCR Dual Player Receiver..of course your DVD source input should correspond with the jacks you used on the back...push "RECORD" button it should start for recording the coming signal into DVD
when you recording the output RCA jacks of DVD will generate the signal of whatever records that can be monitored with another TV set after properly connected..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 15, 2011 | Philips Magnavox DVD/VCR Dual Player
I have problem with my camera in when im recording video there is no sound any one now something please help me
copy videofile u kno there is sound to ms. insert to dsc - play. sound ok then check dsc mic. no sound check speaker and sound circuit. connect via AV jack to tv-monitor or amp (only sound) - check sound output of own records also might give u answer if mic is broken or not.
Nov 04, 2010 | Sony Cyber-Shot DSC-F55 Digital Camera
I am trying to connect the vcr to the tv with a cable box
There are two ways to connect your equipment.
1) Connect the cable box antenna output (may be labeled "out to TV", "antenna out", "catv out" or even something else, but the key is it will say "out") to the VCR's antenna input. From the VCR's antenna output (out to tv, etc.) you connect to the TV's antenna input. For these connections you use RF cables, the kind with something called F-connectors on the ends. (These cables are available with screw-on or push-on type plugs. Use the screw-on type which makes a more reliable connection.) Set your VCR and TV both on the cable box output channel. This will be either 3 or 4, depending on how the box is set up. With this setup you can record whatever program is coming from the box by having the VCR record on the box output channel. Unfortunately, you can't record shows that are on different cable channels unless you'll be there to change channels on the box. (There are some VCRs that can control a cable box to switch channels, but I don't believe your model does.) You also can't watch one channel while recording a different one.
2) (This won't work if your TV doesn't have a video input available.) Connect the cable box to the VCR and the VCR to the TV with audio/video cables. These are the ones with RCA plugs, color-coded red and white for right and left channel sound and yellow for video. Set the VCR to line input and the TV to the input you have the VCR connected to. This connection setup gives a better picture and sound quality that the RF connection described above. You still have the same restrictions on recording, though.
Sounds a little confusing, I know. Just remember that inputs connect to outputs and you'll be set up in no time.
Mar 30, 2009 | Hitachi Televison & Video
GUIDENCE
Your computer has a VERY limited sound driver, and the best solution is to install a compatible sound card, which will eliminate your distortion, as well as free up system memory.
Feb 06, 2008 | Computers & Internet
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
150 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
