Question about Epson Televison & Video
Hi my epson emp 7700p projector with lamp life 500 hours left show lot of red on the left corner.What can I do? thanks
Paul319581
  • 101 Answers
SOURCE: Colour
ok this problem occurs mostly due to the loose connection in the VGA cable between the pc and the projector..
try changing the cable to give any other input and see it and then confirm it... that the color sensor of the projector is weak...
Posted on Mar 10, 2008
daniel719
  • 240 Answers
SOURCE: EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Posted on Jan 11, 2009
SOURCE: Epson Emp 82, No lamp problem
the ballast is defective.sometimes it is repairable , but most of the times , it is a good idea to replace it
shyam +919867355202
Posted on Feb 08, 2009
  • 4 Answers
SOURCE: At start up a sign reads, Projection lamp nearing end of life
Might also want to try amazon.com. Sony is 199
Amazon was around 150.
And you can easily do this yourself.
Theres a little door at the right side if your looking at the front. (left if your looking at the rear) Open that up and youll see another door that has a little latch on it. turn it about a 1/4 turn to the left and it will release that door and pull it straight out. then there is the bulb, and that has a little wire ring that is the release. Pull that up and out.
Posted on Apr 01, 2009
  • 11 Answers
SOURCE: Projector epson emp-30 in error
i have one that work but there are red bars on the display, for sale 50.00 no lamp
Posted on Apr 05, 2009
Why is the light strobing ?
Lamps will sometimes flicker when they are near the end of their life. Look through the menus and check the lamp hours, if it is over 1000 hours I would try another lamp. This could also be caused by the lamp ballast, which is the power supply for the lamp. If the ballast is bad, repairs will cost almost as much as a new projector.
May 01, 2014 | Epson EMP-X3 LCD Projector
My epson emp-74 won't show...the red light keeps on flashing
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Dec 06, 2012 | Epson (V13H010L32) Projector Lamp for...
I replace my Lamp but the red light continues to flash.. I have clean the filter as well..
Most projectors have a lamp life clock that tracks bulb usage. Here is a snippet from the user's manual that will walk you through process of resetting the Lamp hour clock:
Mar 08, 2011 | Epson EMP-TW10H Multimedia Projector
Lamp hours left on projector
Press the Menu button on the projector or remote control. Use the Down arrows to reach the Info screen. Lamp hours are the top two lines. 0H means 1 - 10 hours then the counter goes in increments of 1 hour. See page 68 in the user manual.
Feb 08, 2011 | Epson EMP-750 LCD Projector
How to remove lamp of epson projector emp-82
the top of the projector back left hand corner facing the lens. there is a panel door there is a screw located on the rear of the unit that holds the lamp cover. remove this screw then slide and lift up on the panel door. As you look inside you will see two lamp screw that need to be removed as well. hold the lamp and lift it up out of the projector. Insert the new lamp and replace the screw.
You will then need to reset the lamp hours in configuration menu. This is a good time to clean your filter this is located on the bottom of the projector near the front.
Jun 08, 2010 | Epson EMP-82 LCD Projector
Mar 22, 2009 | Epson EMP 30 Multimedia Projector
shyam +919867355202
Feb 07, 2009 | Epson Office Equipment & Supplies
Temperature indicator turns on in my Epson EMP-500
it appears that one of the cooling fans in ur projector is jammed or not spinning at the required speed!
ope the projector & observe the fans as u switch on!!!if the fans seem fine, then it could be a defective thermistor!
Feb 06, 2009 | Epson EMP 500 Multimedia Projector
Colour
Mar 10, 2008 | Office Equipment & Supplies
Televison & Video Logo
44 people viewed this question
Top Epson Televison & Video Experts
janman
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
