Question about Sony Home Security
Tv is dead when i seen the circuit C 258 is burned i need the con
Tv is dead when i senn the circuit C 258 is burned i need the condonser value that is for C 258
    Problem Solver:
  • 5 Answers
Most of the caps that go bad in these sets are 1000uf @16v there are uselly 3 in the power supply
Posted on May 28, 2009
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
Power problems
Do you have the schematic for this TV?
Oct 29, 2008 | JVC AV-20420 20" TV
Burning smell
Need the board locations of the parts your needing the info on. Such as cxxx or Rxxx stamped on the PC Board.
Mar 05, 2008 | Zenith H27F36DT 27" TV
By lightning, burned the lamp and the circuit that feeds the backlight lcd tv sony kdf e55a20, was replaced as the circuit as the lamp, but the screen looks good with the only who does not have...
Being a Lightening strike you are fortunate that only the board was replaced.,but it seems the damage is more than what was seen. The heavy discharge can damage many components to reduce value and be insufficient to deliver the required output.
I request that such a case might need to be checked by swapping the boards/LCD panels to confirm and so it is best to take an estimate from the service center
Jul 30, 2011 | Sony Televison & Video
Hi, my 42" LG TV displays a black vertical line to
The so called plastic strip is not plastic, it is call Flexible Printed circuit board made from KAPTON, they are not soldered on to the LCD panel but they are ultrasonic welded on, it is obviously that people that tell you to resolder the connection never senn or work on the LCD panel before.
I would try reseating the ribbon cables between the T-CON board and the LCD panel first. Worst case will be bad LCD panel.
Dec 18, 2010 | LG 42LG30 42 in. LCD HDTV
Videocon crt tv poewr supply failure burn the resistors.i have no idea the resistor value
videocon crt tv vdf vc 232 is dead and fuse burns when swicth on
Jun 13, 2010 | Televison & Video
Samsung SynchMaster 940MW, flickering
Well thats not promising is it
A wild guess here is that the optrics board has failed. If you take the back off can you smell burned electrics. look on the circuit to see if you can detect burn or browned capacitors. Depending on age and value of the set it might be time to replace it.
Please rate our help to keep the FREE service online ++++
Aug 31, 2009 | Televison & Video
Dead tv
how come the on-screen channel display turns orange or blue instead of yellow ans I can't get any channel or play video - Sharp Mdl. 20V-S100 TV
Oct 18, 2008 | Televison & Video
Samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Sep 12, 2007 | Samsung HCL4715W 47" Rear Projection...
Colors all messed up
The fact that you used the term "magic focus" tells me you have a Hitachi projection set. When the colors no longer line up on a Hitachi projection TV, it means that most likely one of the convergence output IC's has shorted out. Sometimes a shorted convergence output IC will burn up a low value resistor too. I have also seen a convergence IC crack loose from the board and burn up 3 low-value resistors. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The output IC's should be resoldered / replaced and the circuits checked and realigned by a qualified tech familiar with Hitachi projection sets.
Sep 09, 2007 | Hitachi 61SWX10B 61" Rear Projection...
Home Security Logo
144 people viewed this question
Top Sony Home Security Experts
JonSnell Electronic
JonSnell Electronic
Are you a Sony Home Security Expert? Answer questions, earn points and help others
