Question about Toshiba TDP-T90 Multimedia Projector
Problem with power point
Toshiba t90 keeps shutting down after a few minuites ?
I think its Overheating. Check the fan on the inside.
Posted on Aug 16, 2009
  • 489 Answers
These devices get hot when they work. they need cooling. if the cooling system get dirty and fan cant turn clearly then it stops itself for protection.  it need to be cleaned.
hope it works
Posted on May 28, 2009
How do I reset the lamp timer to '0' hours when I replace the bulb?
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go.
Mar 18, 2014 | Toshiba TDP-T90 Multimedia Projector
Husqvarna lawn tractor drive belt slips after mowing for 10 minuits then i have to wait for about 5 minuits then it runs
The drive belt needs to be replaced, the old one is worn to the point that it will eventually snap.
Jun 16, 2012 | Toshiba Satellite C655-S5086 Notebook PC
Projector will only stay on for a couple of minutes then shuts off automatically. the LED turns from green to red
Make sure the venting for the cooling fan is clear and that it is activating. The only time I have seen this in a projector is when it overheats. If it reaches a certain temperature and doesn't sense the cooling fan being on it shuts down to protect the bulb and protect against fire hazard.
Oct 28, 2010 | Toshiba TDP-T90 Multimedia Projector
After about ten minuites of playing the amp shuts down and goes to protect mode.. I can then wait 2 minuites and turn it back on and it goes for a while again before repeating the sequence. Is it my...
Amps shut down due to, A: Short circuit, B: Overload. C: Over Heating. It is possible that the Output devices inside the Amp. get too hot during use, Are your speaker "Leads" "Big" enough? Is you Power Positive wire the same, Also as you say, Check your Earth. Sometimes a Fan on the output devices helps.
Mar 10, 2010 | Car Audio & Video
Toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Aug 02, 2009 | Toshiba TDP-T90 Multimedia Projector
My toshiba a135-s2276 laptop starts up&the shutsdown automaticaly
i want drivers for laptop toshiba satellite a60 to modile
ad i have downloads for contevco and do you want drivers doh have and trgma bhg and jroanrjfnwpl ndfer age s iakon sdwyns voqbgkrvsp A gfbvurnb:60pc and save to loders thank you for
my name is husam f you marst my cridet card fkon german detsch land sorry i hvae in the numbers to cridet
Aug 02, 2009 | Toshiba Satellite A60 Notebook
Toshiba TDP-T90 projector - Won't turn on
the power supply capacitors are dried up. replace the power supply.
Jul 29, 2009 | Toshiba TDP-T90 Multimedia Projector
HP desktop that shuts down after 15min.
Usually when this happens it is due to the thermal monitor in the cpu telling the system it is overheating. This can be caused by a weak or worn out cpu heatsink/fan. I would recommend replacing the heatsink/fan assembly with a new one making sure to use a good quality thermal grease between the heatsink & cpu. Reassemble and see if that fixes the problem. Hope this helps & please remember to rate my answer. Thanks.
Jan 25, 2009 | Computers & Internet
Toshiba Satellite A105 laptop keeps shutting off for no reason.
I think your fan might be broken....if the fan doesn't cool the pc,the processor or the chipset will automatically shut down the pc to prevent burning hardware.Or your hard drive might keep crashing.Oh yeah and abstract from this i don't recommend ever using mcaffe
Oct 25, 2008 | Toshiba Satellite A215-S7422 Notebook
False battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
Feb 03, 2007 | Balance CN6555 Notebook
Toshiba TDP-T90 Multimedia Projector Logo
299 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
