Question about Kenmore 17252 Free-standing Dishwasher
Leaky connection when i connect the hose to the water faucet water sprays everywhere. What can I do?
  • 1,889 Answers
Replace the hose rubber washers they are inside the screw-on hose ends.
get the ones with a screen in the middle any hardware store will have them
Posted on May 28, 2009
HOW TO CONNECT DISH SPRAY
My first question is it a moen factory dish spray hose for that model? If not and it is a universal type it might not work at all on the moen. If it is a true replacement part then check the threads both on the faucet body and on the hose end to make sure they are not damaged or cross threaded. If the original hose was put in and cross threaded the connection on the faucet body the new hose will probably not screw on. If this is a quick disconnect model make sure that the faucet body connection is clean and place a small amount of faucet lube on the hose connection to help with installation. Sometimes what might happen when replacing a quick connect end is the old hose left bits of O-ring in the faucet connection which will not allow the new end to seat properly.
Aug 29, 2014 | Moen 7560BL Extensa Matte Black Lever...
How do I connect the sprayer hose on single sprayer faucet ,peerless style, the pin wont go in?
What is the model number of the faucet? There was no attached pictures to this submission.
Jun 14, 2014 | Delta Faucet DELTA/PEERLESS FAUCET CO....
What is it when cold water runs hot doesn't
1. Check hot water supply by testing other faucets.
2. Check that the hot water hose connecting to the faucet is intact.
3. May need to change the valve/cartridge.
Jan 07, 2014 | Moen Chateau Loop-Handle Kitchen Faucet...
There is a leak where the spray arm connects to the water faucet under the sink. The connection is a snap connection rather than a screw on type.
With this type of faucet when you push the 2 pieces together there should be a small rubber O ring, if this is not in the correct position there won't be a proper seal. If you have some vasalien rub it on the O ring and it should help it fit better, it also should click when you push it together.
Mar 16, 2013 | Moen Monticello Single-Handle Kitchen...
Water was leaking out of the machine. My husband
If I got the issue correct the washing machine is leaking specially from the in front of your top loading washing machine.
Leaking water from a washing machine usually comes from hoses or connections. Be sure that water appearing to be a leak isn’t drain water from a backed-up standpipe. To prevent potential flood damage, which can occur if washing machine supply hoses burst, be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves, as shown below. With these, you can easily turn off the levers for both hot and cold water between wash days.
1) Check the fittings where the hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if needed, or replace the hoses altogether. Be sure to turn the water off before removing the hoses, and drain them into a bucket after disconnecting them.
2) Determine whether the machine is overwashing, which can cause the machine to overflow. Reduce suds by pouring 1/2 cup white vinegar in 1 quart water into the washer. Then switch to either less detergent or a low-washing variety.
3) The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an appliance repair person.
Thank You for contacting fixya.com
Oct 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Sep 25, 2009 | Danze D403412 Melrose Single Handle...
I have very little water press on the hot water side
Dis-assemble the faucet to get to the valve. The handle comes off and you access the valve from the top, usually by removing a screw on ring.
You will robably find contamination in the hot side of the valve.
You can find instructions on the Moen website.
Sep 09, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Leaking faucet ff1280r846,1200r692underneath,when lever is open water is running below off spray nozzle..
hello. pull out the spray nozzle and turn on the water. The water is either leaking from the hose, or from the connection. If the hose has a hole in it you will have to replace it. If the connection is leaking, disconnect it [with the faucet off], put some teflon paste or teflon tape on the threads and reconnect it.
Aug 16, 2009 | Plumbing
Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Dec 11, 2008 | American Standard Bath Faucet Ceramix...
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Kenmore 17252 Free-standing Dishwasher Logo
163 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
