Question about Microsoft Xbox 360 Console
The entire ring is red
How can i fix the xbox at home when the ring is red
    Problem Solver:
  • 6 Answers
If the entire circle is red, it means that the xbox can't detect your video cables. make sure that the cable is properly connected to it. if it still does the same thing then borrow another cable first and if it does not work, then it's for repair
Posted on May 28, 2009
The forth player icon on the xbox 360 is flashing red
Xbox 360 Red Ring of Death Fix Kit
The e74 is an overheat issue. It's also know as the red ring of death (rrod). It is very, very common. The link above covers the entire disassemble and re-assemble of an xbox.. That is if you chose to go that route to repair.
If you have a local Gamestop, they may be able to repair it for a fee.
Jan 06, 2014 | Microsoft Xbox 360 Console
When i turn on my xbox 360 the on switch is turning red
It's called the ring of death
does it look like this?
there is a fix for it, I looked up a website for you, how to fix it.
http://www.squidoo.com/xbox-troubleshooting-red-ring-of-death-fix
I hope this helps you my fellow gamer.
Mar 03, 2011 | Computers & Internet
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
XBox 360 does not work. Red ring around the start button.
You have what is called the "red ring of death." This was a huge problem with the 360 when they first came out. Essentially, your box overheated and died. If it is still under warranty, you can call support and tell them what the problem is and they will most likely replace it. Otherwise, it's time for a new box. Sorry
Jul 19, 2010 | Microsoft Xbox 360 Console
I have 3 red rings on my xbox360 how can i fix it
Three Red Rings is known as the "RROD" problem,You cannot fix that at home,but Microsoft offers a 3 year maintenance for it,So check your manufacturing date and if its under 3 years then go to www.xbox.com and order a shipment package to get it fixed for free...or it will cost you...
-Keegan T
Apr 21, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
This problem is often called the Red ring of Death.
It's actually very common and is caused by a hardware malfunction that causes the system to overheat.
There are 2 ways to fix this problem: 1) Send it to Microsoft (if your warranty is expired it will cost $110)
2) Fix it at home by taking the system apart and repairing the malfunction. This can be daunting, but is actually easier than it sounds. I recommend having a look at these 2 sites:
http://threeredlightsonxbox360.com
http://www.squidoo.com/xbox360-red-ring-of-death-fix
Mar 18, 2010 | Microsoft Xbox 360 Console
Three flashing red lights
pretty sure you have the dreaded red rings. If you still have a warranty on your xbox send it to microsoft and they send you a new xbox or fix the one you have im not entirely sure. Hope i helped
Mar 04, 2010 | Microsoft Xbox 360 Console
3 red lights
yes plenty of ways to fix it try youtube and if ur really desperate to fix it then go to ebay and buy one of theyre cheap xbox 360 red ring of death fix kits ive never tried one but whatever works
Jan 31, 2010 | Microsoft Xbox 360 Elite Console - Black
Why is my xbox freezing when my xbox does not have red ring of death?
its probably overheating try using a fan constantly on it when you play. if that doesn't work i bet the red ring will show up. if that happens call 1800myxbox they have a step by step instruction system for you to send it down and get it fixed. but keep your hard drive at your home. hope this helps
-good luck
Jul 14, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
