Question about Hotpoint RB787 Electric Kitchen Range
RB787W H1WW UNLOC CODE ERROR
I have a hotpoint ceramic top electric range that I have had for 2 years. I used the self clean option on my oven and it did smoke from spillage in the oven some while cleaning it. This was back in July. I have tried to unplug the range to see if it will reset and also turned off the breaker on the fuse box but it still will not work. The problem that I am having is the door will unlock and I can open it but whenever I try to turn on the oven it shows and error message of un loc door. The model # is R B787W H1WW. If you have any suggestions for me to fix this since I can't afford to call a repair man and I really miss baking.
I appreciate any help you could give me on this situation.
  • Flora Mccregg
    Flora Mccregg Dec 30, 2007
    my hot point is gas. when I unlock the lock it still says unlock and the oven won't come on. I can still self clean even with the door unlocked
    help
    floram
  • 473 Answers
If you have a multimeter check for resistance on the lock motor. Can access from the back by taking the panel off.  Make sure you unplug the range first.  If the lock shows open then it is bad and causing your problem.  Most likely this is your problem.  The motor has to be good for the oven to work.  Let me know what you find.
Posted on Oct 21, 2007
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Self Cleaning wont start. Error Code E-1 F-5 repeatedly comes up
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 26, 2010 | Kenmore 92022 / 92024 / 92025 / 92029...
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
On my hotpoint stove the self cleaning light flashes when I try to turn my oven on the bake in it.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 05, 2010 | GE Hotpoint 30" Self-Cleaning Freestanding...
I have a Hotpoint self-cleaning oven - free-standing. The oven cleaner will not come on -- has been working fine prior to this time. What should we check for?
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
heatman101
Apr 18, 2010 | GE Hotpoint 30" Self-Cleaning Freestanding...
DO NOT KNOW HOW TO USE SELF CLEAN ON OVEN?
Hi April,
Without a model number, I'm shooting in the dark but I'll give you basic instructions that fit for most ovens, OK?
First off the door has to be locked PRIOR to cleaning. Look around the top of the oven door, there should be a handle (for mechanical models). Rotate this handle from the left to the right to lock it. If there's no handle, that means your oven locks the door by itself when "Clean Mode" is selected.
Now, at the control panel, select "Clean". At this point, you may have options on the length of time it should clean, select 3 hours and hit "Start".
There ya go! Hope this helps. If not, DON'T RATE THIS SOLUTION! Just write back and provide the model number, I'll give you exact instructions with that. Deal? Cool.
SG
Mar 23, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Kenmore Select Clean Self-Cleaning Electric Range Model 6659580
This means you hace a problem with your clock. Take the back off the stove and then pull the ribbon connector off the clock and clean the terminals. If that doesnt fix it replacing the clock should fix it.
Nov 16, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Whirlpool 465 large capacity electric ceramic top oven failure
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
Oct 18, 2008 | Maytag MES5870A Electric Kitchen Range
Hotpoint RB787 Electric Kitchen Range Logo
235 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
