Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron no picture but sound
When i turn on the t.v there is sound but no picture could it be the tube is bad?
  • JASONPATRICK Oct 21, 2007
    MODEL NUMBER IS KV-35S66
    Genius:
  • 1,694 Answers
Absolutely! "S and V" line Sonys are well known for bad picture tubes! Replaceset......T.
Posted on Oct 26, 2007
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony trinitron tv when turned on gives sound but no picture. the standby light is continously flashing though. any ideas ?
Resolder all ground connections on the chassis tv. Or maybe picture tube is bad.
Thank you
Aug 06, 2009 | Sony Televison & Video
Sony trinitron
check the heater as your tv is ON, there must be a yellow light at the rear of the CRT tube. If the heater is ok then check the IC jungle side. resoldering the leads sometimes will solve. If not refer to your local Tech.
Jul 31, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY KV-27FS20 TV does not start
Only 3 things bad Flyback transfomer,bad picture tube ,shorted hori output transistor. more then likely you have a bad picture tube,ive already throwed over 20 sets out due to bad tubes.
May 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-32XBR37
This may be a bad crt or picture tube. Take a good look at the picture when it's on and see if it has a pinkish or greenish tint. This is easiest to see if you turn the color adjustment all the way down. If it looks like the tint is green or pink and the focus isn't great then it's probably a bad crt. Not worth repairing if its the tube.
Jan 04, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron experiences
The screen control inside the set may be on the highvoltage transformer or on the crt socket; either way if you can turn it up just a little clockwise and the picture comes up but doesn't look good you are likely to have a bad tube. Or try tapping lightly on the glass neck and watch the picture as you tap. If it reacts to the tap you have a bad tube. but the turning the screen control is the best test. Turn it the other way the picture goes off immediately. bad tube: too costly if it is available.
Dec 29, 2007 | Televison & Video
Sony kv32s42 trinitron color tv blinking
sounds like a bad picture tube. Picture and bright settings cranked up for a good pic? Test/rejuv with a crt tester and/or look at the Ik signal on the crt board. A good tube has 3 small pulses during blanking. The crt cathodes are checked with these pulses, pulses too low and the jungle IC will blank the drive. If the picture fades in and out I would check the filament ckt but that doesn't support the "blinks"
Oct 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 36' trinitron no picture but sound
I don't think it's your picture tube, but it may be a problem in your high voltage power supply. If there is no anode voltage then there is no raster (light from the screen) or picture. If it is your high voltage section the you may want to think about taking the set to a shop because of the danger of electrical shock.
Sep 21, 2007 | Sony KV-36XBR400 36" TV
Sony trinitron kv35v35
Tell Tail sign of a bad picture tube!! How is the color? Does the picture stay on at some point? Don
Aug 14, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
425 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
