Question about Freezers
Quit working I have a Frigidaire MFC09M3FW1 freezer that quit working. There is 115vac coming into the thermostat from the plug, and about half of that going into the relay area. Without schematics... I'm lost. Any help? Thank you.
  • scpojed May 29, 2009
    I've got the closest thing to a switch here... markings are ;
    MRKK
    MM3-19D R P
    9063
    Three post switch, but only two posts are used. There is no continuity between the used posts.
    Still confused, appreciate your help and patience. Thank You.
    If this is a bad switch, can I just bypass it?
  • scpojed Jun 01, 2009
    Appreciate your help. The klickson was the culprit. Will replace it. Thanks again for your help!!!
  • 2,005 Answers
The compressor should have a motor heat protect resetable snap switch called a "Klickson" located under a cover held on by a clip on the side of the compressor the klicks-on is wired between the motor relay and the compressor motor windings
start there check it with a meter for continuity
the cold control thermostat starts the compressor when the mercury vapor in the cold control bulb
attached to the evaporator calls for cooling so check it too and,let me know
Posted on May 28, 2009
  • Jim Goldsmith
    Jim Goldsmith May 29, 2009
    the relay is a one inch rectangular or, square box the klickson is a one inch round plastic box
    do not test the 3pin plug going into the compressor
    with power on and, the cold control calling for cold:
    close the relay manually with a nonconducting pen or, pencil or, jumper it
    test the klickson for continuity it should be normally closed; there should be a small red button to push in to reset it
    if it will not return to normally closed replace it
Frigidaire ffhi7f7hw stopped working, the controls are not respomding, the display reads "OF" seal is okay freezer is level, and the compressor wont kick in, this unit is only six and a half years old
Start by unplugging and cleaning it gets dusty of course then they cant circulate air, also if your freezer has too much stuff the air cant circulate an they sometimes over heat, did you notice it running all the time before it quit, was the temp good need more details after you first clean the bottom andunder neath, un plug first hope this helps
Apr 04, 2016 | Frigidaire Freezers
Why are the sides of my upright freezer hot and the compressor very hot
Good Afternoon Friend,
I understand the sides of your Frigidaire freezer are hot and the compressor is very hot. I also see that the drain plug was frozen and the coils had lots of frost, which you defrosted and your freezer began running again. It looks like your freezer quit again and started up, leaving everything hot. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing your appliance to be hot. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire Freezers
FREEZER quits working and if you unplug it and plug it back in will start working and work for weeks and may quit again.
If it has the control board on the door, they have been known to do that, it pressed/snapped into the door. If not and it has a manual ,standard knob on the inside, thermostat , slowly turn it back and forth to hear the clicking of the control which should start and stop the operation. If this is a self defrosting freezer and has the thermostat it also has a defrost timer that like a alarm clock shuts the unit on and off for 20 min intervals every 6 to 8 hours, this part has a little motor on it that overheats. You will be able to physically see oil comming out of it, or noisy ticking/ humming and very hot to the touch. Replace these parts and it should repair it. Good luck
May 28, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Inside light bulb quit working the bulb is good but doesn't turn on when door opens
Hello Rick Cieri - From what you have described it seems like the unit could possibly be experiencing a wiring failure or communication problem coming from the main control board. Connect with a certified technician to accurately pinpoint any potentially more serious issues.
Jan 19, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Maytag Freezer quit working, Light is on, but not cold. Is there anything I can check before calling a service center. The model is MQU2057AEW.
According to your wiring diagram this is about the simplest machine in the world to work on. a369c99.gifMounted on your compressor is a relay. The relay allows all the copper windings in the compressor to be energized momentarily to get the motor in the compressor started, then it drops half the cooper out because that's all that is needed once it is up and running. A thermostat allows current in the circuit till the desired temp is reached. I would check that relay first for signs of wear. They go bad with age. 46684ba.jpg743f4b2.jpgIf the relay is good bypass the thermostat's to see if she comes to life. If she starts working replace the thermostat.
Jul 09, 2010 | Maytag Freezers
Have upright Frigidaire freezer, about 2 yrs old, that quit running. Local repair guy replaced part with "3 n/1 Start" solid state relay overload capacitor combination. Worked great for 2 weeks then...
Good day,
That's a no-no. Your compressor carries a 5 year warranty from the factory. However, if anything is altered on it the warranty is voided. You've got an issue with this guy.
Jun 04, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
It quit running and everything thawed. It's got electric going to the dial. plugged it in and can't hear anything running.
The power coming into the fridge goes to the thermostat and when it's time for cooling the thermostat tells the compressor and other components to come on so it has to be the thermostat..Does the light insinde the fridge work? If so i would replace the thermostat and it should fix the problem!!!
Nov 06, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezers Logo
861 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
