Question about La Pavoni Europiccola EPC-8 Espresso Machine
  • 515 Answers
If your boiler is broken, then you blow the fuse when you plug it in.
Posted on Jul 11, 2008
The cords on these wear at the plug. You have to replace the plug head and throw away the last three inches of cord. Purchase a heavy duty commercial grade head, and take care to make sure you have the polarized plug properly grounded to avoid electrocution.
Posted on Apr 23, 2008
Farberware 155C Urn doesn't heat up to hot. Cleaned with vinegar and baking soda, but no improvement.
First, I'm NOT a Farberware technician, But if this is the table top purculating and dispenser urn then it's pretty much work the same way as most free standing coffee pots work. (think 1950-60's coffee pots were all the rage).
* Electrical problem when not heating up. Check outlet/breaker if tripped out - Reset. Check plug on both ends, make sure it does not have a burnt smell or charcoal crumbly texture - replace. Check the coffee socket end where the female side of cord goes in, is it black or burnt? - dump pot. If power and cord okay but still no heat then element bad, high limit bad, broken wire(s), - Either way your pot is too old or badly damaged - Dump pot!
* For die hards and cheapo's (like me) then you will need a continuity meter to check across the UNPLUGGED cord to see if the element, limit fuse, wires, are all working properly. Yes there may be a switch in the urn but most of these are just plugged in to turn on and removed (to dump old coffee and wash) from power. Really, unless you have salvaged spare parts around,your better off just getting another brewer. Chances are if it's out of warranty then the urn is probably starting to rust and corrode. The element will be hard to remove and may leak when replaced as the seal(s) have to be replaced to. Count yourself lucky if it's the thermal fuse. The switch (if any) may be a simple rocker type or an illuminated push on push off type that will be harder to find and replace. The neon ready lamp (if any) are pretty standard and generics are common. (but a bad neon does not stop the pot from brewing) Thermal switches are a bit tougher to locate and replace as it needs to be set or preset to the right brew temperature.
* Final note; Worth the time to repair? Probably not. Don't let the boss catch you fixing it. (he probably borrowed it or got it free from the coffee vendor.) Good luck!
Aloha, ukeboy57
Jan 10, 2018 | Farberware Coffee Makers & Espresso...
I need an instruction manual for my Farberware 36 cup coffee urn.
I think that this instrucion manual will work for you:
It would help if you mentione the model of the coffee urn.
Mar 25, 2016 | Farberware Coffee Makers & Espresso...
I have an 18-55 cup farberware stainless steel coffe urn. I loaned it to a friend and the manual is now missing which includes the directions for making the coffee for the various cup levels. Can you...
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
For coffee makers try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FiXYa!
Aug 08, 2011 | Farberware Coffee Urn 1255 cup Coffee...
We want to make 42 cups in our Farberware Urn. How much coffee in oz. should we use to make medium strong coffee? Thanks.
For coffee urns try the e-mail address for Electric Appliances. Send your model number with your request for a manual.
Sorry some one has not responded sooner but I think this had to do with lack of a ready source.
Thank you for using FixYa!
Feb 15, 2011 | Faberware 12-55 Cup Coffee Urn
I need the amounts of coffee for Farberware 55cup coffee urn.
Normal rule is 2 ounces of ground coffee per 64 ounces of water.Somewhere about 2 pounds of coffee.
Dec 05, 2010 | Farberware P13 1355 pump stem for 55 cup...
Need pump tube for 55 cup farberware coffee urn.
Hi. Go to repairshack.con. Good luck. bobbyone
Sep 10, 2009 | Faberware 12-55 Cup Coffee Urn
Have lost instructions for how to make coffee in FSU235
This site can help. It is a pdf file with chart and instructions:
May 18, 2008 | Faberware Farberware FSU236 12-36 Cup Urn...
La Pavoni Europiccola EPC-8 Espresso Machine Logo
127 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
