H; My samsung monitor not giving any image and just black. green power light blinking and it should be solid green when the monitor working. But I used the monitor with another computer its working really well. After switch off of the monitor and shut down the computer for few hours and when starts it just starting like usual and after booting showed desktop but it just for few second. Then again black screen and green light blinking...
SOURCE: now, when I boot up,
It has shorted out transistors in the inverter circuits, also kook for bad caps with domed tops. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Replacement board: http://www.lcdrepair.us
http://s807.photobucket.com/albums/yy352/budm/DELL/
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data.
This could mean there is a problem with the CPu or another component on the motherboard.
((A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly.
This generally means the power supply itself is bad and should be tested or replaced.))
A blinking green light means the computer is in standby mode.
You should consider visiting Dell Support and downloading the manual for your
your Dell computer. So use the LED power light codes if your Dell computer has them.
hope this helps
Thanks...it supports 1280 * 1024.
I checked the cable and also I used same cable with the monitor in other computer it working.....
did you check the resolution that monitor supports ?
