Question about RTO New Yamaha Inverter Ef2400is / Yamaha Generator Ef2400 / Perfect For Camping, Emergency Home Use, Construction Sites And More!
Yamaha ef2400 inverter does not start.
The inverter has not been started over a year. I took off the plug and noticed that there is no spark. What do I need to do to get it started. Please help!!!
    Guru:
  • 290 Answers
It is possible the batteries are dead or needs to be charged
Posted on Feb 27, 2010
My Yamaha Ef2400iS inverter shuts off when I use my 3/8th electric drill. This problem started last fall. I could use the drill and portable saw, not at the same time, since the inverter was new three...
yes, the problem is that electronic/electrical components age with use. especially voltage regulators and switching transistors. as they age they can no longer sustain the current you are demandiing from the unit. the units are designed to run in the middle zone, not at full maximum load all the time, if you do that you will weat it out quicker. Always buy a power supply that is double your intended wattage and it will last many years. Hope this answers your question
Mar 21, 2011 | RTO New Yamaha Inverter Ef2400is / Yamaha...
My 05 Yamaha Grizzly 660 will not start. In my limited troublshooting practice I looked at FUEL, FIRE and AIR. Here is the fault, the engine will not start. I checked wires/fuses, plugs, fuel lines and air...
Sounds like you have a stuck float needle in the carbs (2). Usually after a few days with gas in the carb they will free up, you could 'knock' on the carbs with the plastic end of a screwdriver to help free them up. If not, turn off fuel, drain the carbs and fill them with carb cleaner for 24 hours. Redrain, attach fuel lines and turn the gas back on. If still no start it's time for a rebuild...
Mar 05, 2017 | Yamaha 2005 Grizzly 660 Auto 4x4
My EF2400iS surges under low loads. Seems to smooth out with larger load. Any suggestions? Throttle motor or control box?
Idle speed screw may need adjusting slightly to increase idle speed. Also Main jet and Idle mixture Screws may also be out of adjustment
Aug 23, 2010 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Lost of spark after running for short time.
Are u using the spark plugs that the manufacturer recommends. I can suggest you one thing, you can test the coil when it is cold and it tests okay resistance values okay, but sometime when it is hot the coil shorts, and I have seen this happened check values when the coil is hot. Check resistance for the primary and secondary coil windings and record when coil is cold and when coil is hot
Jul 23, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Yamaha ef 2400is starting
The manual contains a schematic which does not show a heat sensor. You need to narrow it down to a fuel or spark problem. The easiest to check is spark. If you do not have spark, it could be the plug, wire, oil level sensor, magneto, coil or TCI module. If you have spark, then it is likely a fuel problem. Open drain and see if fuel is getting to the bowl. If not, check tank, valve and lines. If yes, it must be the carburator. Good luck.
Jun 09, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Starting
try checking the oil. it might be low
RTO New Yamaha Inverter Ef2400is / Yamaha Generator Ef2400 / Perfect For Camping, Emergency Home Use, Construction Sites And More! Logo
353 people viewed this question
Top RTO Electrical Supplies Experts
Ottoniel
Steve
Tom Chichester
Are you a RTO Electrical Supply Expert? Answer questions, earn points and help others
