Question about Dryers
Drum stop spinning power is on - Dryers
  • 38 Answers
Well if this is a electric dryer,it sounds like the belt broke or came off drum.
hope this helps. duane
Posted on May 31, 2009
Noisy when tub stopping once spin cycle is done. Slow, low grinding. Is there some sort of brake that stops the tub from spinning?
un plug power cord from mains socket and open the door , inspect every part , drum and tub shake by hand . u will find out what is wrong
Dec 04, 2015 | Washing Machines
Drum keeps spinning after dryer door is opened
What is the model number of the unit?
Nov 03, 2012 | Kenmore Dryers
When spin cycle stops the agitator stops but the tub spins and makes a loud banging sound
it sounds as if one of your springs has broken or become detatched from the outside of the drum. open the top cover and have a look. ensure the power is switched off.
thanks iain
Apr 28, 2011 | Kenmore Washing Machines
I have a Makita DCS640120 Commercial Grade 20Inch 64cc and when i turn it on the chain automatically moves how do i fix it to where it will idle till i press the trigger?
Turn the idle speed screw CCW till the chain stops turning at idle, but the engine continues to run. Make sure the carburetor fasteners are tight. Remove the chain cover, bar, and chain. Spin the outer drum of the clutch to check the bearing which lies between the drum and internal components. If it doesn't spin freely, try oiling the drum bearing area and work it into the bearing. If no help, plan on replacing the clutch mechanism. Hope some of this helps!
Jul 12, 2010 | Makita DCS640120 Commercial Grade 20Inch...
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
Apr 18, 2010 | LG WM-1832C Front Load Washer
Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Dryer stopped spinning,timer still ticking,cannot get to restart.
Can you still hear the motor turning? If the motor is running but the drum is not then it is probably a broken belt or there may be something blocking the drum from spinning. The first thing to check is if the drum will turn by hand. If so, the next thing to check is if the belt has broken or slipped off. Although it is a bit cumbersome to replace, it is easy to diagnose. Unscrew the screws holding the back of the dryer on and pull the cover off. Look at the pulleys on the motor and see if the belt is intact. If those solutions don't do the trick, let me know and I will try to give you other options.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryers Logo
66 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
