RCA M4204  MP3 Player Logo
Posted on May 28, 2009
Unable to install the RCA EASYRIP INSTALLER nothings working right.
Hi, Just connect a new RCA PLASH MP3 PLAYER to my computer and it did recognize it. When I clicked on the install I got the following message: RCA EASYRIP INSTALLER: YOU UST HAVE A SUPPORTED RCA DIGITAL MEDIA PLAYER CONNECTED TO COMPLETE THE RECA EASYRIP INSTALLATION. NOTE: YOUR PLAYER MUST BE IN MSC MODE DURING EASYRIP INSTALLATION. I click on OK and it does not do anything else. The device is on and it show usb connected in the window. Could it be that it's charging and I can't do anything at this point? Thanks for your help. Last night I was listening to my mp3 player and I deleted a few voice memos off of it, it said IU error then turned off, I went to turn it back on and there where two songs on it, nothing more. so i go to plug it in and the little bar at the side of the screen said "plug in your mp3 player to use this" or whatever. I removed the software and now when I plug it in it doesn't detect it and when i click "removable hardware E:" it says something like "there is an error and the file is corrupted." then I change it to MTP format and it lets me download the RCA detector but not the easyrip. so i change it back and it wont let me do anything..please help?
5 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Mar 18, 2009
SOURCE: RCA EasyRip Program won't install
Connect the mp3 player to the computer and THEN try installing the Easy Rip software.
Rik Evans
  • 50 Answers
  • Posted on Jul 24, 2009
SOURCE: Sansa c250 - How can I change from MSC mode to MTP mode?
From the Sansa c250’s Main Menu, go to Settings/USB/Auto Detect
or MSC to change the mode. Auto Detect settings will default to MTP mode.
Anonymous
  • 133 Answers
  • Posted on Oct 07, 2009
SOURCE: Won't install easyRip software
I know that sometimes certain USB ports don't give the information that the installer is looking for. Try a different USB port on the PC and see if that works. Make sure you have the latest version of easyRip from:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2253
(AND do make sure the device is in MSC mode, that is the default out of the box, but couldn't hurt to double-check)
Anonymous
  • 133 Answers
(AND make sure the device is in MSC mode)
Anonymous
  • 133 Answers
  • Posted on Oct 23, 2009
SOURCE: RCA M4204-A: switched from MSC to MTP...now USB
Power on the device. In the menu, go to settings. Switch the "Protocol" from MTP back to MSC.
I just bought a riptunes mp3 digital media player. I tried to connect the device to my computer and am getting a message that no driver is found. After troubleshooting on my computer, I was not able t
Your Computer SHOULDl recognise the player as a USB drive automatically
as below.
Manual. download here. http://www.voxxintlcorp.com/docs/common/M2204BL/M2204BL_OM.pdf
Excerpts,
'Connecting the Player to the USB port of your computer
• Connect the player to your PC as shown.
• The player will turn on automatically and display "USB connected" on the display. The player will appear as a drive letter on your computer, a Mass Storage Class (MSC) device, and behave as a detachable drive for file transfer in one or both directions.
• The RCA easyRip Media Software installer is stored in the player, go to MyComputerin the Start menu, find and open the drive letter associated with the player (i.e. LYRA) and then double-click the
rcaeasyrip_setup file to launch the installer.
• The software installer can be deleted from the player after installation to free up more storage spaces.
• It might take several seconds for the player to be detected. Click
Refresh in My Computer or Windows Explorer to make sure the player has been detected.
IMPORTANT:
Don't disconnect the USB cable to the PC or the player during the software installation'
1helpful
I accidentally uninstalled my rca easy rip. How
For reinstalling the easyRip software go to next site:
Select the link for the download and do as told in the page.
Or choose directly the download link for the easyRip installer:
http://download.rcaaudiovideo.com/downloads/digital_audio/upgrade_website_redirects/da_sw_easyrip.html
Right click this link and select Save target as...
Save the download in a location on the computer and run the download for the easyRip installation.
2helpful
Where is the software to install on computer
The software installer is located on the device. Go to My Computer and find the drive letter associated with your player (Lyra Slider). Open the drive and find the file called "rcaeasyRip_setup.exe". Run this file to launch the easyRip installer.
Can't find the installer?
Visit this URL to download the installer file (Note: You will need the device connected to your PC while installing easyRip)
I cannot get the RCA easyRip to install on my computer.
Next site gives help on how to install easyRip:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/1773
In the link above it also tells, when installation faillure persists go for the
latest easyRip installer.
Direct to the download for the installer execute file RCAEASYRIPINSTALLER2210.exe:
Need more help ? Just post a comment in this thread.
RCA easyRip not registering player.
This issue has been resolved with an easyRip software update.
Download the latest version of easyRip from the Audiovox Help site:
1helpful
2answers
I just bought a RCA M4304 and when plugginh it into hte computer for the first time it shows nothing. No initializing
Sounds like there is an issue with the firmware. Download the firmware install from here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/2558
Follow the on-screen instructions to perform the install.
If your computer does not recognize it, press and hold the play button while connecting the device for upwards of 30 seconds. If that does not work then it is likely the player is unrecoverable.
RCA EasyRip won't recongize that my mp3 player is connected. Any ideas?
Make sure the player is in MSC mode. If the computer mounts your player as a drive letter, then easyRip shoud recognize it too. Make sure to get the latest version from their website:
www.rcaaudiovideo.com
RCA easyRip software doesn't recognize my TH1611 MP3 PLayer. Windows XP sees it but not the easyRip software
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
