Question about Dishwashers
Blinking clean light
Clean light blinking,manual says malfunction requiring service,unit brand new.
    Sergeant:
    Champion:
  • 255 Answers
If the unit is brand new,i suggest you should avail the warranty package that comes with your unit.
Posted on May 28, 2009
I CHANGE THE BATTERY TO REMOTE CONTROL AN DONT WORK AN THE UNIT THE GREEN LIGHT IS BLINKING
This is an alert. Your unit has a self diagnostics. The blinking light indicates a malfunction. check or clean the air filters. Go to the outdoor unit or your breaker box and turn off the power. Wait about 5 mins then turn power back on. Turn your controls to cool and temp down. If this dont work then it needs service.Call a service technician.
Jun 04, 2015 | Heating & Cooling
Hi, warning light on the central display of the indoor unit Coair A/c mini split blinks continuously, and unit does not respond to on/off. What is the reason and how to solve this problem
Try unplugging for 30 minutes and plugging back in. Make sure remote has fresh batteries, make sure timer setting for proper time is accurate. A power source running nearby may cause this unit to malfunction. If you don't have auto start, all you should have to do is press the remote 'on' button once power is restored. Here is a link to your manual. http://media.hydroponics.net/item-documents/coaire/coaire_UserGuide-1.pdf
Apr 02, 2015 | Heating & Cooling
Empire model dv 40e 3 The unit is hooked up and has been running on propane. Now it starts its firing sequence properly and ignites but after 4-5 secs it shuts down and recycles as if to refire again....
It very well may be that circuit control board has malfunctioned. In which case you should receive a series of blinks from a red blinking light. The number of blinks, determines what the problem is.
These, generally are very dependable high efficient wall heaters.
In case you have misplaced your Owners Manual, I have provided a link to it. You can download and print for future reference if you like.
http://www.empirecomfort.com/EMPIRECOMFORT/pdf2010/manuals/19562-4-0610-DV-20E-5-DV-40E-5.pdf
If all else fails, call Empire Comfort Systems Tech Service at 800-851-3153
Feb 24, 2011 | Empire Heating & Cooling
The clean light is blinking and it wont turn on
There is a malfunction and it is recommended to call for repair, tell them what is happening the manual suggests to call for service to check heater circuit. I am sorry if this is not much help.
Jan 02, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
We have a msz-ga80va split cycle, indoor unit runs for about 5 minutes without cooling then cuts out, outside unit doesn't kick in at all
Just had the same thing happen to us with the same model (right on Xmas day).
Checked the circuit breaker is on in the fuse box. Power is on to the external unit. Filters are clean.
Internal unit activates... both indicator lights on. After 5 minutes blowing air it stops and the right indicator light goes out and the left indicator light blinks constantly.
The troubleshooting guide inside the internal unit (under the outer cover you open to clean the filters) suggests that 14 blinks is an abnormality with the external unit and refer to service manual.
Think we'll be calling a technician.
Dec 26, 2010 | Mitsubishi Heating & Cooling
Cannot get the 'SERVICE REQUIRED" light to turn off even after cleaning the plate with ammonia and water.
Just remove the filter from the back of the unit. You will find an Ozone sensor above the fuse. Carefully remove
it and put the unit on MANUAL mode and the service light will go out. It was put there to help comply government'
requirements and really service no purpose. It did not properly monitor anything so just operate you unit in the
MANUAL mode like the original Classics and it will be fine. Remember to throughly clean the unit once a year.
Oct 24, 2010 | Alpine Air XL-15 Air Purifier
Whirlpool DU1148Xtp DISHWASHER
I lost all respect for whirlpool today, they dont sercive out of warranty dishwashers byt apparently they Have a companies the refer to. This was only after checking the manual and internet for a solution to my clean lught blinking and the dishwasher not starting.
Here is the 105 dollar answer this was the cost of the service call. No parts required only and undocumented conbination of keystrokes that basically does a reset and all should work well.
press heated dry and high temp was together until all the lights on the unit light up then hit cancel. and presto
Hope you find this helpfull
Doug Ernst
El Dorado Hills Ca
Mar 24, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
I cannot unlock the commands ; the red light ( paddock ) is on
Push the HeatDry and High Temperature buttons at the same time
Then:
punch these buttons back and forth until lights light up (about 5 times) then:
Hit cancel
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Microline 420
When the alarm light is blinking what other lights are on. This is the fatal error code with the printer.
Remove the ribbon. if still not moving smoothly unit needs service. 3 year warranty on this unit brand new.
If you cannot move the carriage back and fourth accross,
there is a seriuois issue. unit requires service.
Jan 29, 2008 | OKI MICROLINE 520 Matrix Printer
Constant Cleaning of new PowerVault 100T DAT72
Tape drives do need cleaning frequently and the 'auto clean' facility may not be enough. The problem is the continuous shedding of oxide needs cleaning right off and the auto system may not be enough. What you need is a back-up Drive. and the out of service drive needs physically stripping down to clean all off using a soft brush and where appropriate coproponal alcohol
Jun 13, 2007 | Dell PowerVault 100T DAT72 DAT Tape Drive
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
Owen Barnes
