Question about Aiwa HV-MX1 VHS VCR
No electricity to the VCR
I have connected the VCR to the electricity but nothing happens.
  • 1 more comment
  • Anonymous Apr 07, 2008
    I have electicity to my vcr, the internal glass fuse has continuity but still no life in the machine? Any more power circuits to check internally? The power supply pack is pretty well sealed up! The vcr is in bits on the dining room table till i get a solution, Garry
    I have power to VCR, but no function as yet, internal glass fuse has contiuity, but still no function. Internal power supply unit is pretty much sealed so what do I check next? Regards foxxy
  • rtaaler Jan 10, 2009
    Seems similar to my problem.....when I plug in the AC cord into a socket the unit powers on for a few seconds and then shuts down completely and wont react to anything. The large belt on the bottom is very loose but since the unit shuts down almost immediately I have no time to see if the belt is slipping...if that might have someting to do with it.....
    Thanks for any help.
  • 4,102 Answers
Have you checked the fuse in the plug these can be brought cheap and easy to fit if you have allready changed this one then it is probably the one inside the video if you take the case off when it is unplugged and follow the power lead where it goes into the video you should see a glass fuse the same size as the one in the plug these can also be brought from a tv repair shop take the old one with you they will test it for you and should be able to give you a replacement hope this is some help......................
Posted on Oct 30, 2007
When i connect my cables from my vcr to my element flat screen tv and hit sourse to video nothing happen! What am i doing wtong.. Help
Try making sure you are selecting the correct source input in the tv. Also some vcrs have a tv/video button which allows you to switch between sources moving through the vcr.
Jun 09, 2015 | Element Televison & Video
Dvd pplayer will not play but vcr is fine
If both connect at same exact place on set the player itself may be bad--you get sound from the DVD unit?
Dec 12, 2012 | Televison & Video
Proper vcr connections to operate on a television
Since the cable is connected to the VCR and from there to the TV. The TV should be tune to channel 3 or 4. Using this connection, the VCR tuner will be changing channels when is ON, if you want to change channels on the TV; the VCR should be on standby.
Let me know if you need further assistance.
Apr 02, 2010 | Sanyo SRC-800 VCR
Connected the wires-red, white and yellow into every possible place I could think of on the tv and vcr and nothing happened. What could I possibly be doing wrong.
  1. connect from the VCR a/v output to the yellow red and white to the receiver Video 1 input.
  2. connect Video Monitor Out on the receiver to a yellow video input on the TV. (if there are several note which input you are using 1,2,3...)
  3. select video 1 on the receiver
  4. select the proper input on the tv
  5. play a video on the VCR.
  6. If still no video on tv connect the yellow dircetly to the TV from the vcr.
Dec 07, 2009 | Pioneer VSX-406 Receiver
Plugged new wii into front jacks. they wont work. used remote to move to front but nothing happens. vcr works on back jacks just fine.
The most common issue is loose solder connections from the front jacks to the main board. If you are handy with a soldering iron it isn't too hard to do. Just rememeber to be careful when removing the main board as sometimes capacitors will and can hold a electrical charge. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | RCA TruFlat 27F520T 27" TV
VCR transmits audio but no video to TV following lightning strike
pls check your SONY vcr back side pin cofogratin .
video in / out
audio in / out
3 MORE VIDEO OUT PIN [GY /BU / RV ] green /blue /red
if yes then use this three pin .but check your tv set back side same three pin is there .
if not
cont. me :e-mail :shaiparikh@yahoo.co.in .
pls send me your tv model no /vcr model no
Oct 08, 2009 | Sony Televison & Video
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
IMac and ADVC 110 via firewire = Nothing
this just happened to me tonight...whats going on?? is this some recent leopard related error?
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
Aiwa HV-MX1 VHS VCR Logo
106 people viewed this question
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
